'67 F-100 Project
09-21-2017, 01:29 PM
I'll figure something out. Don't have to take off much to get them to match up.
09-29-2017, 09:07 AM
Finally able to get the bottom of the box done! After taping it off, shot two coats of epoxy primer.
09-29-2017, 09:09 AM
Also, I ordered a new tailgate post from LMC. It’s actually the right gauge of metal, surprisingly. So, shot it in epoxy also.
09-29-2017, 09:11 AM
Then shot two coats of black urethane.
09-29-2017, 09:12 AM
Looks good Pat, should make you feel a little more relieved getting that done
And finally, 3 coats of 3M body shutz undercoating.
09-29-2017, 09:20 AM
Subscribed, Pat! What a great build thread!
09-29-2017, 10:04 AM
Thanks Jason! As you can tell, I’m a glutton for punishment!LOL
09-29-2017, 10:50 AM
Nice to see that you got that part of the bed done and keep up the good work.
09-29-2017, 11:39 AM
Thanks man. Hope to have the tailgate put back together this weekend.
09-29-2017, 11:41 AM
Great job on the under coating...that should stand up to whatever the 'Braska Highway Department can throw at it!!!
09-30-2017, 11:18 AM
Time to get this tailgate back together. I’m using the handle to help center the upper peice on. Screwed the back side on, then flipped it over. Using several different clamps, started from the center, and spot welded out. As you can see, it has a pretty good arch in the center, so it was a pain to get just right.
09-30-2017, 11:20 AM
Welded the front, then did the rosette welds on the side, and the back. Now, just have to clean up the welds, and see how it looks. Going to order the new hardware today, so I can mount it back on the bed.
09-30-2017, 02:20 PM
10-01-2017, 10:52 AM
Thanks! Spent some time yesterday cleaning up the welds. Just have to strip the old paint, and then shoot it in epoxy.
