Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 08-30-2009, 08:05 PM
skytower31's Avatar
skytower31 skytower31 is offline
Garage is empty, add now
skytower31 is starting off with a positive reputation.
Console Removal
I'm trying to get my center console apart and I can't seem to get chrome ring around the shifter out. Is that required to get the main panel out around the shifter? I'm able to get the parts around the radio out no problem, but I'm trying to run a cable from behind the radio to the center console storage area.
Any suggestions would be much appreciated.
Thanks!
  #2 (permalink)
Old 08-31-2009, 10:33 AM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is gaining momentum as a positive member of FTE.
PM me with your email addy and I will send you the instructions from the manual.
__________________
1978 F250 Lariat 4x2
2008 Expedition Eddie Bauer 4x2
  #3 (permalink)
Old 08-31-2009, 11:44 AM
skytower31's Avatar
I don't seem to have PM privileges yet...
  #4 (permalink)
Old 08-31-2009, 11:54 AM
berry1234's Avatar
ok, whats your email? spell it out so you don't get spam.
__________________
  #5 (permalink)
Old 08-31-2009, 11:55 AM
skytower31's Avatar
jon broom field @ g mail No spaces obviously.
  #6 (permalink)
Old 08-31-2009, 11:57 AM
berry1234's Avatar
Email sent. Let me know if you need anymore info.
__________________
  #7 (permalink)
Old 08-31-2009, 12:00 PM
skytower31's Avatar
Much appreciated.
  #8 (permalink)
Old 08-31-2009, 12:06 PM
berry1234's Avatar
No problem. The ring does come off. I would use a skinny blade wrapped in tape or similar so you don't scratch the finish.
__________________
  #9 (permalink)
Old 08-31-2009, 12:08 PM
skytower31's Avatar
Email hasn't come through yet. Did you add the .com after gmail?
  #10 (permalink)
Old 08-31-2009, 12:23 PM
berry1234's Avatar
Quote:
Check now, I sent john...sorry. Should be there.
__________________
  #11 (permalink)
Old 08-31-2009, 12:32 PM
skytower31's Avatar
Got it. Thank you.
I just can't get that ring off...I'm sure I'm going to break it. Even tried prying at it with a putty knife. May have to look for some alternate routing possibilities.
  #12 (permalink)
Old 08-31-2009, 12:49 PM
berry1234's Avatar
It may not need to come off. Try taking the rest of the parts off first. I would assume the ring wouldn't cost a ton if you did break it.
__________________
  #13 (permalink)
Old 08-31-2009, 04:33 PM
08 Navigator 08 Navigator is offline
08 Navigator is starting off with a positive reputation.
On my 08 Navigator, I pried up the woodgrain panel under the bezel with a putty knife and the chrome ring came off in one piece. I got the tip from somewhere out in internetland; I can't find it again, otherwise i would send you a link.
Open up the center console arm rest, and pry the trim panel up from the rear edge. The chrome ring comes right along with it. I struggled through all of this when I put a factory navigation system in my new 08. (The Nav system was from a 07 and it plugged right in and worked perfectly.)
Good luck with it.
  #14 (permalink)
Old 08-31-2009, 05:01 PM
berry1234's Avatar
There are some bolts that need to be removed before you can pry it up. I believe the Nav console is a little bit different than the expy.
__________________
  #15 (permalink)
Old 08-31-2009, 05:20 PM
skytower31's Avatar
Quote:
The only bolt I can find is the one under the rubber storage area at the base of the stereo/HVAC vertical console.
Tags
1978, 2001, 2008, center, console, expedition, f150, f250, ford, instructions, navigator, removable, removal, removle, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
