electric choke adjustment eldebrock 1406
Iam having trouble adjusting choke. What is the procedure, choke wants to stick open on new carb. Do you adjust opening with engine off?When I push peddle to floor on cold start the fast idle doesnt engauge. Is temp outside affecting this. should fast idle cam work at first cold start every time? or does outside temp have effect on this? Thanks
Heesman
09-05-2014 03:00 PM
yellow78ford
03-23-2007 12:29 AM
gearshift101
11-29-2004 08:22 AM
ant truck
09-14-2004 11:19 AM
