460 Engine swap questions
My dad and I are swapping in a 1990 f250 460 into his 1989 f250. We have run into a problem. The 89 engine had the TFI module on the distributor along with a wire harness connector going to it. The 90 engine does not have the TFI on the distributor (presuming it was located on the fender) or a harness plug for one. So for obvious reasons we are getting no spark to the disributor. The question is this. Do we need to find or buy a TFI from a 90 f250/460 and wire it into the harness (might be a usable plug on the fender) or do we need to just install the wiring harness from the 89 f250/460 along with the TFI module from that 89 engine? Any help would be greatly appreciated.
-mybg4x4
-mybg4x4
wow, took a while for someone to answer, thank you for trying. we actually had to end up switching out the harness itself. The 1990 harness did not even have a place for the TFI to hook into. In 1990 they switched the TFI over to the fenderwell. So we just switched the harness and dist. and fired right up....
bbf385
08-06-2014 05:23 PM
90vinG
05-01-2013 10:39 PM
73FOMO
08-21-2012 04:26 PM
jeffpr2000
07-28-2011 09:01 PM
Jrod13
15
08-03-2007 06:40 AM
