What Are You Doing To Your Truck?
#62
the vise was free and the hole was in the bumper for the vise bolt hold down so that is why it is there. i have a 7 pin on my truck now, but it was attached to the part of the bumper that i cut off so i need to find a new place for it right now it is just hanging down.....and i did use the vise today to grind the paint off the reciver tube, the bumper pulls out 3 feet for a cab over camper so we pulled it out and it made it very esay to work on, the bumper is welded mostly on and is a pain to pull out and put back in not worth it...
#66
Oh and Brady - that setup looks good! I do really like the black bumper compared to the silver too.
#67
There are six-pin and seven-pin diagrams on this site:
Trailer Wiring Diagrams
Use the seven-pin one for standardization with all pickup trucks sold in the last ten years or so.
At a minimum, wire the right-turn, left-turn, tail-lights, and ground.
The auxiliary is sometimes used for backup lights.
The +12 volt wire is used to charge a trailer's on-board battery to apply the brakes in case of a break-away. Small trailers without brakes obviously don't use this feature.
The brakes wire is from a trailer brake controller to apply electric brakes (if used).
Pop
Pop
#70
#72
Working on making a stealthier Excursion(if there is such a thing) as far as radar and laser encounters on road trips..
IR laser absorbing paint on front reflective surfaces(lights and blue oval)..
New radar detector..
Remote color display mounted in dash for radar detector..
Laser jammers will be installed next.. All in good fun..
#74
