5.0 liter with NP435 transmission, possible?
on
Don't know if it you could get one from the factory but you can use the bellhousing from a 300 six and a 351W work on a 302, the 351Ws would be from 82 and up I think and the 300 could be from just about any year. Check F250s and 350s will be your best bet for a 435. If you find one with a 351W make sure the balance is correct they changed to a 50oz counter weight in the 80s instead of the earlier 28, and the 300 is internally balanced so you will have to find the right flywheel.
-Johnboy
-Johnboy
reamer
10-10-2016 11:18 AM
1984F150Guy
03-11-2014 11:24 AM
OzFTrucker
11-30-2013 04:25 PM
kingford72
07-19-2011 09:02 PM
