73 and 77
on
1 Post
i know with my truck which is a '79 F-150 reg cab *originally a long box, but the previous owner put it on a '76 F-100 short box frame in the late 90s, but now its more a '77 than a '79
as of now, i got the '79 Cab sitting on a '77 F-150 4x4 swb frame and from what i have seen the '79 cab fit nicely on the '77 frame, not sure if the frame is a late '77? but the box and the cab and the '76 front clip/grille fit right onto the '77 F-150 swb 4x4 frame with no problems,
so that's my take on all of this, also the change of spread of the frame rails is only in the rear from what i understand, thus box bolt location will be off, and from what i understand all reg cabs will fit on all reg cab frames no matter the size or year, but the beds will differ, thus drilling new holes in the box may be needed when swapping boxes around,
-Brent
-Brent
The last High Boy was assembled before serial number Y20,001 which was roughly midyear 1977.
High Boy rear frame rails are 33 1/2" apart. 2WD's and other 4WD's rear frame rails are 37 1/2" apart.
All 1977 F100/350's look basically the same. In fact, excepting the left Styleside quarter panels, all the exterior sheet metal is the same 1973/77.
Styleside left quarter panels: 1973/76's have exposed fuel caps, 1977/79's have fuel doors.
what about the grill difference from the 73-77 and the 78-79? I have a 76 350 with the round headlights, but I'm thinking about doing a 78-79 grill with the square headlights. If the sheet metal is all the same I would imagine the shape of the grill shell is the same also. Any one ever do this or have experience with it? And a $100 for a no rust truck! You better go buy a lotto ticket right away!
