06 F250 with shaker 500
Hi Guys, maybe someone can help with a small problem with the display illumination? I installed a new 6pack from an07 ford 500 and it worked great but i lost the steering wheel controls, i thought that ok as long as i got the 6 pack. Then along came a shaker 500 unit out of an 05 mustang and it works with everything except the illumination is backwards,(bright during the day, dull at night, and doesn't adjust with dimmer switch)
It be nice to remedy this if possible, if anyone has any suggestions that be great.
Thank you
Thank you
2005/6 F250
Radio 12v
lt. green/purple
radio harness
Radio Ground black and black/lt. green - radio harness
Radio Ignition pink + radio harness
Radio Illumination lt. blue/red (dimmer) + radio harness
Factory Amp Turn-on N/A
Power Antenna N/A
LF Speaker +/- orange/lt. grn - lt. blue/wht +,- radio harness
RF Speaker +/- white/lt. grn - dk. green/org +,- radio harness
LR Speaker +/- gray/lt. blue - tan/yellow +,- radio harness
RR Speaker +/- orange/red - brown/pink +,- radio harness
Radio 12v
lt. green/purple
radio harness
Power Antenna N/A
Thank you ReAX for your reply, I have the schematic for the radio from a mustang forum showwing the 3 plugs on the back and telling what each pin is for. I just don't know if lum+ or the lum- is what i'm looking for, maybe needs swapping? I'll have to see if
(Radio Illumination lt. blue/red (dimmer) + radio harness) is onto which pin. I still need to open my dash to wire my rear amp power on somewhere into the circuit. it,s just hooked to a wire that turns on in acc and run. any suggestions on where best to hook it up?
Thanks again on the quick reply and for your help.
Wealthk1
1999 to 2016 Super Duty
168
02-18-2018 10:36 AM
xyfalcon500
05-27-2002 12:50 PM
