Door in F-350
Old 09-13-2010, 11:25 AM
Jterr's Avatar
Jterr
Jterr is offline
Door in F-350
First off thanks to all the info posted here about Water Pumps and Fuel Leak problems. I have fixed all of the above and she is back on the road.
The next question refers to the doors,so not sure if this is the right place to post.
Can the doors be adjusted or put back where they are supposed to be. My driver door has a droop to it and doesn't close and have been getting a water leak at top/front while sitting still.
Any suggestions
Thanks
JT
Old 09-13-2010, 11:46 AM
DRRXR's Avatar
DRRXR
DRRXR is offline
A little door info
I used this as a guide after getting my new door insulation lip seal installed.
Stovebolt Tech Tip -- How to Install Door Latches and Adjust Strikers
its not exactly like ours but in general it applies
Forgot to mention check your hing pins to make sure that they are still tight and have no play
Old 09-13-2010, 12:52 PM
GT_350's Avatar
GT_350
GT_350 is offline
I would check the hinge pins & bushing's first, both my doors on the passenger side need them done.
best way to check is have someone lift the door and look to see where the movement is, it's hard to do this by yourself.
If thats not it, then yes you can loosin the bolts, use a jack with a wood block and jack it back in place.
Good luck
Old 09-13-2010, 06:02 PM
Jterr's Avatar
Jterr
Jterr is offline
Good luck
It looks like they are loose. How do you get them out ;Cut?????
Old 09-13-2010, 07:19 PM
GT_350's Avatar
GT_350
GT_350 is offline
Cutting would be the fastest way, if you have a air hammer you can knock the top of the pin off, and drop them out the buttom.
papagiddyup
Georgia Chapter
03-04-2013 04:08 PM
cwendel
2009 - 2014 F150
08-13-2012 08:43 PM
rickfitz
1997-2006 Expedition & Navigator
05-21-2011 09:32 PM
jpar19
11-26-2010 10:31 PM
highway90
13
02-09-2006 08:58 PM
Quick Reply: Door in F-350
