Oil & Lubrication
1988 F150 Oil Pressure Gauge Problem
Old 03-04-2001, 06:55 PM
mefsh's Avatar
mefsh
mefsh is offline
Old 10-25-2001, 04:18 PM
mdeamico's Avatar
mdeamico
mdeamico is offline
I have a 1988 Ford F150 with a 5.0. The oil pressure gauge will read in the middle, then all of a sudden it goes to zero. A while later it will start to read again. I assume that there is a problem with the switch/sending unit, but I can't find where the sending unit is. Can someone tell me where the sending unit is on my 88 F150 with a 5.0?
Old 10-29-2001, 08:46 AM
lanero's Avatar
lanero
lanero is offline
It is located directly above the oil filter. It is a small can shaped thing with a wire lead connected to the top of it. Takes about 10 minutes to replace (once located). I replaced mine about a year ago for the same problem.
Roger Lane
Test Analyst
Sr. Automated Test Engineer
bradphx
67
01-10-2024 06:12 PM
Aerostar
01-14-2015 03:16 AM
miko6810
Modular V10 (6.8l)
06-04-2014 06:14 AM
1978 - 1996 Big Bronco
05-25-2002 03:08 PM
broom
11-24-2001 12:46 PM
Quick Reply: 1988 F150 Oil Pressure Gauge Problem
