1997 Ford 4.6 exhaust manafold leak
Here's a link to it on our site if you would like to check it out.If you have any questions I'd be glad to answer them for you.
Ford F150 Exhaust Manifold
Just remembe to be careful, our f150s have aluminum heads that can make the process of taking the bolt a little more challenging. If a bolt breaks use a bolt extractor and make sure you do not drill into the head or you will have a bigger nightmare to deal with.
As said before a nice coating of PB blaster a few times before the job will help immensly.
If you are experienced with aceletaline (SP) torches you can heat the bolt (make sure its just the bolt) to almost red, hit it with a hammer, and unscrew the bolt. It breaks down the electrolisys process that creates a bond between steel and aluminum metals. Over time the metals are know to bond together by electrolisys.
doublecanister
30
05-22-2012 06:32 PM
74crwcb429hibPS4spd
04-14-2003 06:51 PM
ivanhoe 66
12-05-2001 10:33 AM
