Removing 4r100 from 2001 f350
Old 08-04-2009, 10:13 AM
robjs111's Avatar
robjs111
robjs111 is offline
Anybody have any instructions or ideas on proper way of removing a 4R100 trans out of my 2001 f350 7.3 4 x 4 CC SB??
Thanks.
Old 08-04-2009, 12:57 PM
WA.Ranger's Avatar
WA.Ranger
WA.Ranger is offline
<TABLE width="95%"><TBODY><TR><TD>SECTION 307-01: Automatic Transaxle/Transmission
</TD><TD align=right>2001 F-Super Duty/Excursion/Motorhome Chassis Workshop Manual
</TD></TR><TR><TD>REMOVAL
</TD><TD align=right>Procedure revision date: 04/15/2003
</TD></TR></TBODY></TABLE>
<HR>Transmission
****** name=tps_proctitle content=Transmission>
<TABLE border=1 cellSpacing=0 cellPadding=3 width="50%"><CAPTION>Special Tool(s) </CAPTION><TBODY><TR vAlign=top><TD></TD><TD vAlign=top>Retainer, Torque Converter
307-346 (T97T-7902-A)
Removal
All vehicles
  1. Place the transmission range selector lever in the NEUTRAL position.
  1. NOTE: All gasoline vehicles will have new adaptive shift strategies. Whenever the vehicle's battery has been disconnected for any type of service or repair, the strategy parameters that are stored in the keep alive memory (KAM) will be lost. The strategy will start to relearn once the battery is reconnected and the vehicle is driven. This is a temporary condition and will return to normal operating condition once the powertrain control module (PCM) relearns all the parameters from the driving conditions. There is no set time frame for this process. If a concern is present during downshifts or converter clutch apply, it is not the fault of the shift strategy and will require diagnosis as outlined in the workshop manual.
    The customer needs to be notified that they may experience slightly different upshifts (either soft or firm) and that this is a temporary condition and will eventually return to normal operating condition.
    Disconnect the battery ground cable. For additional information, refer to Section 414-01 .
4x4 vehicles
  1. Remove the transfer case assembly. For additional information, refer to Section 308-07B .
4x2 vehicles
  1. Remove the driveshaft. For additional information, refer to Section 205-01 .
All vehicles
  1. If transmission disassembly is required, drain the transmission fluid.
Vehicles equipped with a fluid pan drain plug
  1. Remove the drain plug and allow the fluid to drain.
  1. Install the drain plug.
Vehicles not equipped with a fluid pan drain plug
  1. NOTE: Do not discard the gasket unless damaged. This is a reusable gasket.
    Remove the transmission fluid pan and gasket.
  1. NOTE: The transmission pan gasket is reusable unless damaged.
    NOTE: Apply a light coat of petroleum jelly to hold the gasket to the fluid pan.
    Position the gasket onto the cleaned fluid pan. Make sure the magnet is positioned over the dimple in the fluid pan.
  1. CAUTION: Mixing the 4x2 and the 4x4 style transmission fluid filters and transmission pan assembly components can cause transmission damage.
    Install the correct pan with gasket for this application. Alternately tighten the bolts.
  • CAUTION: Make sure securing straps or the transmission jack adapter do not touch the cooler bypass valve (CBV). Do not use the CBV as a handle. Damage to the CBV can cause a leak.
  1. Install a suitable transmission jack and support the transmission.
4x4 vehicles
  1. Remove the jack stand after installing a suitable transmission jack.
4x2 Excursion
  1. Disconnect the wire loom from the crossmember.
  1. Remove the crossmember bolts.
  1. Remove the transmission mount nuts and the crossmember.
F-Super Duty and 4x2 vehicles
  1. Remove the RH crossmember nuts.
  1. Remove the LH crossmember nuts.
  1. Remove the nuts and the crossmember.
All 4x2 vehicles
  1. Remove the transmission mount.
Vehicles equipped with a transmission-mounted parking brake
  1. Disconnect and lubricate.
    1. Disconnect the parking brake lever return spring from the parking brake lever.
    1. Apply penetrating oil to the adjusting clevis, jam nut and the threads on the front parking brake cable and conduit.
  1. Disconnect the front parking brake cable and conduit.
    1. Loosen the jam nut.
    1. Remove the clevis locking pin.
    1. Remove the clevis pin.
    1. Remove the adjusting clevis from the parking brake lever.
  1. Compress the retainer, and remove the front parking brake cable and conduit from the cable bracket.
All vehicles
  1. NOTE: If the vehicle is equipped with a power take-off unit, all or part of the PTO unit will need to be removed.
    Disconnect the shift cable from the transmission.
    1. Disconnect the shift cable from the manual lever.
    1. Remove the shift cable bracket from the transmission and position aside.
  1. Disconnect the digital transmission range (TR) sensor connector and the wire loom from the shift cable bracket.
  1. Disconnect the solenoid body connector.
  1. Disconnect the turbine shaft speed (TSS) sensor and the output shaft speed (OSS) sensor.
  1. Remove the wiring harness from the transmission and position aside.
Gasoline engines
  1. Remove the flexplate inspection cover.
    1. Remove the bolts.
    1. Remove the inspection plate.
  1. Remove the starter motor. For additional information, refer to Section 303-06A or Section 303-06B .
  1. Remove the cylinder block opening cover.
  1. Remove and discard the torque converter-to-flexplate nuts.
    • 5.4L engine has four nuts.
    • 6.8L engine has six nuts.
Diesel engines
  1. Remove the starter. For additional information, refer to Section 303-06A or Section 303-06B .
  1. Remove the inspection cover.
    1. Remove the cover.
All vehicles
  1. Position a suitable drain pan and disconnect the transmission fluid cooler tubes from the cooler bypass valve.
  1. Remove the transmission.
    1. Remove the six transmission-to-engine (diesel) mounting bolts or seven transmission-to-engine (gasoline) mounting bolts.
    1. Gently rock the transmission side-to-side to disengage it from the locator dowels.
    1. Move the transmission and the transmission jack rearward to clear the engine flexplate.
  1. WARNING: The torque converter is heavy and can result in injury if it falls out of the transmission. Secure the torque converter in the transmission. If the torque converter is dropped, a new one must be installed.
    Using the special tool, hold the torque converter in place.
  1. CAUTION: Use care while removing the transmission to avoid obstructions.
    CAUTION: Do not use the cooler bypass valve as a handle. Damage to the cooler bypass valve assembly can occur or damage to the case can result.
    CAUTION: If a safety strap is being used to hold the transmission to the high-lift transmission jack, place the strap behind the cooler bypass valve (CBV) to prevent damage to the cooler bypass valve.
    Lower the transmission out of the vehicle.
  1. Remove the transmission-mounted parking brake.
    1. Keep the parking brake vent in the upward position to prevent contamination of the brake shoes and linings.
    1. Remove the six bolts, parking brake assembly and the gasket from the extension housing.
    • Discard the bolts and the gasket. Clean the mating surfaces.
All vehicles
  1. If the transmission is being overhauled or if installing a new transmission, carry out the transmission fluid cooler backflushing and cleaning. For additional information, refer to Transmission Fluid Cooler — Backflushing and Cleaning in this section.
Old 08-04-2009, 01:00 PM
mudbug04's Avatar
mudbug04
mudbug04 is offline
I have never removed my transmission personally i had a friend do it and rebuild one for me but here is a basic transmission removal procedure if it helps...
http://www.atsdiesel.com/PDF/Transmi...lation-b_1.pdf
Old 08-04-2009, 06:43 PM
Layson's Avatar
Layson
Layson is offline
biggest thing is make sure you have a good tranny jack and strap it to keep it from falling over. Plus LEAVE THE TRANSFER CASE attached. It will balance perfectly attached to the tranny. You will also need a whole bunch of long extensions. To unbolt it the easiest just use long extensions from the rear of the truck all the way up to the front...
Old 08-04-2009, 07:52 PM
lostmybeer's Avatar
lostmybeer
lostmybeer is offline
Have a nice Beer!!!
2 bolts on top reach over from drivers side. Pull out trans dip stick too. Drop rearend down some to access those upper bolts. You can have it out in about a half hour if your quick. have had mine out 2x in the last month.
Steven, wish Woodburn was this weekend. Fixed TC and fuel problems.
Old 08-04-2009, 10:57 PM
WA.Ranger's Avatar
WA.Ranger
Tom, did you get your pinion seal in? Oh, I found your beer also, you left it at Marks. It's gone now though..........
Old 08-04-2009, 11:38 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
PowerstrokeJunkie is offline
Ive had many transmissions up and down, and the transfercase has always been a bitch if it was still attached. it always wants to hang down, is hard to get the dowels aligned, and usually requires a second jack to lift it up level.
Old 08-05-2009, 11:05 AM
lostmybeer's Avatar
lostmybeer
Have a nice Beer!!!
Prolly gonna do it this weekend over at the neighbors...He's got all the air/tools.
Old 08-05-2009, 11:22 AM
WA.Ranger's Avatar
WA.Ranger
Right on. I was going to say that there is going to be another tech day in Sept. So we could tackle it there.
Old 08-05-2009, 12:36 PM
robjs111's Avatar
robjs111
robjs111 is offline
just wondering if u know what size sockets u used? u can do all from underneath truck?
thanks.
robjs111's Avatar
robjs111
robjs111 is offline
thanks.
Old 08-05-2009, 05:25 PM
WA.Ranger's Avatar
WA.Ranger
If I remember, 10mm 13mm 14mm 15mm been a couple of months since I last had mine out though.
Old 08-05-2009, 08:51 PM
mueckster's Avatar
mueckster
mueckster is offline
A 19mm or 3/4'' socket is needed for the bellhousing bolts, also.
Old 08-05-2009, 09:47 PM
robjs111's Avatar
robjs111
robjs111 is offline
how was the drive?
Old 08-05-2009, 10:15 PM
mueckster's Avatar
mueckster
Originally Posted by robjs111
how was the drive?
Everything went smoothly. Fixin' to hit the hay and get an early start tomorrow morning. Talk with ya' later.
Quick Reply: Removing 4r100 from 2001 f350
