I need some ac help
I need some ac help
I turn my ac *** to ac and it only blows out the defrost. And when I turn the *** to floor,dash or floor-defrost it all blows out the defrost.....I looked behind the glove box and when I turn the *** the actuator that controls the flap does not move..I moved the actuator by hand and all it does is switch from defrost to floor and when I let go it goes back to defrost.
Any ideas????
Eric
Any ideas????
Eric
Ok thanks everyone. I checked for leaks and could not find any. with the engine running and the ac on I turn the 4 wheel *** to 4 high and the air started to come from the dash vents...And when I turned it back to 2 wheel it stayed blowing out the vents. But when I turned the ac off and then back on it came out the defrost again.
So any ideas what I need to do now????
To add to the bizarre AC thread...
My AC too has been coming out the defrost for a few months. Once or twice it would slowly come out the vents, sometimes it blew half/half. But a few weeks ago it started to work as normal. There was a weeks or so of a "fluttering" type sound when it switched over.
Everything seems to be working normal now. But I'd like to find out why, and if possible, fix it.
How do you tell for sure if the auto-locking hubs engage or not. It goes into 4WD, and the light works. I did have a time recently that I know the front tires were spinning.
/tg
/tg
I doubt your hubs actually locked in 4wd. If you can spin the front driveshaft or either axleshaft w/trans in neutral - hubs not locked. You can also jack one front wheel at a time and if tire spins while in 4wd - not locked...
After verifying vac IS going to hubs, check hubs following these directions:
http://www.guzzle7pt3.com/allube.php
Pump running all the time likely indicates a leak. Pretty sure mine only runs for a minute or so every once in a while.
Its possible there is a leak elsewhere in your vac system causing hubs not to lock/unlock correctly.
The other common 4wd issue is the relays. These are in little boxes near underhood fuse box. This is usually where to look if 4wd lite on dash doesn't respond to 4wd switch/****...
Thanks skyskijason. I found the leak. It was the solenoid valve. The hubs seem to still be locked in.Would the relay be part of why they are still locked?
Thanks again and here is a pic.
http://s158.photobucket.com/albums/t...t=girls006.jpg
