Update: Back-Up Camera Install finished
A few weeks back, I installed and mounted the viewscreen for my back-up camera.
A couple weeks ago, while up in Oregon for the Riffraff Performance Tech Day, along with some help from Peter (Duck Fan), I finished wiring up and installing the rest of the system.
I figured I'd share the install with the rest of you guys.
Here is the monitor installed on the trans tunnel floorboard.
In the above picture, next to the brake controller, you can see a plastic knockout where Ford places the power pedal switch.
I decided I didn't want to wire the camera to the reverse lights, only powering it whenever I put the gearshift lever in reverse, so I installed a rocker switch there, powering the camera whenever I wanted, not just when it's in reverse.
Here's a picture with the dash popped off to access the wires to the pedal switch harness:
After getting power to the rocker switch, I ran the wire to the antenna down the frame of the truck and drilled a small hole under the drivers side door sill, placing a grommet in the hole, then placing the antenna in the void and hooking the wires to the module.
Here is everything all finished.
Stewart
Stewart
Great pics and congrats on the install!
I've had mine installed for about a month now but I just used it for the first time yesterday to hook up my trailer. I can barely see the top of the ball in my screen but I managed to nail it first try.
Thanks again to VaSheriff for hooking me up with the deal of the year so far!
Looks good.
I'm getting pretty good with mine. 9 out of 10 tries, the ball is dead under the hitch first try. That 1 other time, it's either too far or too short but at least it's straight on.
Oh, I think I'm going to just rewire mine to the parking light. That way the lights will act like the toggle switch you have and if I'm driving at night and don't want it on, I can just turn the monitor off. That way I have controll over it but still don't have to run a wire all the way from the dash to the rear. (Too lazy and too busy to do that.)
They were initially on sale for $41 bucks, but by the time I clicked on the thread, they had dropped down to $25 bucks.
Nice install. I have one of those little rocker switches tho and the blue LED is pretty bright at night - at the correct amgle, it's actually blinding.
Stewart
sweet setup stewart
sams club, i think i need to go their today and pic 1 up what brand or model number is that unit , that seams like a deal i can't pass up
i guess the wife was right this X is going to turn into another project truck just like my old XJ rock crawler i can hear it already
