Shackle Leveling Kit Install How-to??
Old 07-30-2009, 09:04 PM
jkidd_39's Avatar
jkidd_39
jkidd_39 is offline
Anyone got a guide on how to install a front leveling kit?
The shackle type off ebay?
http://cgi.ebay.com/ebaymotors/ws/eB...category=33585
Thanks all.
Old 07-30-2009, 09:54 PM
HKusp's Avatar
HKusp
HKusp is offline
Thanks all.
That is the one I have. It's pretty straight forward. You unbolt the rear shackle on the front spring, Jack the truck up, fit the new one in, you may need a bottle jack to line it up. Then put the bolts back in. It also comes with directions in the box, if I remember correctly.
Old 07-30-2009, 10:13 PM
jkidd_39's Avatar
jkidd_39
jkidd_39 is offline
I got the box.. but no directions.. darn
Old 07-30-2009, 10:22 PM
bdrummonds's Avatar
bdrummonds
bdrummonds is offline
Yeah, the shackles are the inexpensive parts at $50, the directions cost another $300.00, if you want them included.
Its pretty straight forward Andrew, no problems when I did mine (yes, I have the same kit).
Ohh, wait, Have a ratchet strap handy. After you get the first side done, when you remove the bolt for the second side, the spring will want to move out of line a little and youll need the ratchet strap to pull it back into place.
Old 07-30-2009, 10:26 PM
HKusp's Avatar
HKusp
HKusp is offline
I used a porta power now that I think about it. I didn't want to volunteer you Brandon to help him out without checking with you first.
Brandon is very good at walking you through it. I am not neqrly as good at remembering all the details like he is Andrew.
Old 07-30-2009, 10:33 PM
HKusp's Avatar
HKusp
HKusp is offline
Here are some pics of them with the comparrison between the old ones and the new.
The new one is so much beefier. Nice pieces for the money for sure.
Old 07-30-2009, 10:51 PM
bdrummonds's Avatar
bdrummonds
and here is what the finished job will look like
Old 07-31-2009, 02:25 PM
big poppa's Avatar
big poppa
big poppa is offline
I got the same kit also Andrew, just be careful when unbolting, those springs are under alot of load, use the bottle jack or strap like the guys mentioned to relieve the tension and to line the holes back up when you put the new shackle in.. Jacking just the body up on the front end helps alot.
Old 07-31-2009, 02:43 PM
redfire42's Avatar
redfire42
redfire42 is offline
How is the ride with those Vs add-a-spring types?
Old 07-31-2009, 08:29 PM
jkidd_39's Avatar
jkidd_39
jkidd_39 is offline
Installed.. pics to come..
The spring is bent backwards tho.. it now longer has a Shallow U shape.. It is bent slightly past horizontal..
Is this normal?
Thanks all
Old 08-01-2009, 08:15 AM
big poppa's Avatar
big poppa
Is this normal?
Thanks all
Mine does a bit, yes. O yea, congrats.
Old 08-01-2009, 07:25 PM
jkidd_39's Avatar
jkidd_39
jkidd_39 is offline
Alright.. I got some pics for everyone..
These were sanderson welding shackles..
However. They were about an 1/8 too narrow so some bending was required to make them fit. Anyone else have this problem?
All and all it really sucked installing these. But I am very happy with them..
Ohh.. and one of the springs flexed in and that was really sucky to find a way to bend it out. One skid steer fork through the wall of my shop later we got it working. ugh...
Here are some pics.
Before.
<a href="http://www.flickr.com/photos/35223180@N03/3779616372/" title="Before by shady0667, on Flickr"><img src="http://farm4.static.flickr.com/3088/3779616372_0bf8c25dd9.jpg" width="500" height="375" alt="Before" /></a>
After.
<a href="http://www.flickr.com/photos/35223180@N03/3779617212/" title="After by shady0667, on Flickr"><img src="http://farm3.static.flickr.com/2578/3779617212_acae77b965.jpg" width="375" height="500" alt="After" /></a>
Really improves the look of the truck. And I know understand why I need a lift. The truck looked mean when it was sitting all jacked up...
Enjoy!
Old 08-01-2009, 07:34 PM
big poppa's Avatar
big poppa
Looks good, hows the ride??
Old 08-01-2009, 07:57 PM
jkidd_39's Avatar
jkidd_39
jkidd_39 is offline
I think it's a little rougher but it might be Missouri's great roads!
Old 08-01-2009, 08:08 PM
beanhead6D5's Avatar
beanhead6D5
beanhead6D5 is offline
Andrew,your dad is SO going to take your truck from you,LOL.
Does it ride as rough as my truck with a lift?
Quick Reply: Shackle Leveling Kit Install How-to??
