Why is A/C colder at idle?
Old 06-04-2010, 04:32 PM
BigDogg460's Avatar
BigDogg460
BigDogg460 is offline
I know this thread is probably older than my truck but I have been doing some research on the trucks AC issues. I looked at the chart and got my readings today from my gauges.
High Side is 295
Low Side is 34
Outside air is 95 degrees today.
recommended for this outside temperature is:
220 & 42
What do I need to do to get to these numbers. It gets hot as hell in TX and i need some cold AC.
  #32
Old 06-16-2010, 02:00 PM
markford166's Avatar
markford166
markford166 is offline
anybody know where the A/C cycling switch on a 1999 F350 w/7.3 diesel is ?
  #33
Old 06-16-2010, 04:32 PM
60RatRod's Avatar
60RatRod
60RatRod is offline
High Side is 295
Low Side is 34
220 & 42
I am no A/C expert by any means but it sounds like the system is overcharged. R134 unlike R12 systems can be overcharged so try letting some freon out. You may want to consider taking to a local shop they have recycling equipment which is better for the environment than just releasing into the atmosphere.
  #34
Old 06-16-2010, 08:55 PM
Lead Head's Avatar
Lead Head
Lead Head is offline
That is highly illegal. DO NOT do that. You need to have it taken to a shop to have the charge checked.
Trying hosing down the condenser, and make sure that the fan clutch is locking up with the A/C on - if it has an electronically controlled fan clutch.
  #35
Old 06-16-2010, 09:46 PM
SpringerPop's Avatar
SpringerPop
SpringerPop is offline
There are no "electronically controlled fan clutches" in these things. We're kinda' "old school" in here.
Pop
  #36
Old 06-17-2010, 12:46 AM
Fat Diesel's Avatar
Fat Diesel
Fat Diesel is offline
Do you mean compressor clutch? There's an electro magnet that pulls a plate against the pulley on the AC compressor if that's what you're talking about.
  #37
Old 06-17-2010, 09:26 AM
SpringerPop
He's cautioning about ensuring cooling air flow through the condenser. That would be fan.
Some vehicles have electric fans, albeit not ours, and if they didn't switch on for any reason would cause the problems noted.
Compressor clutches, as you know, are a completely different thing.
Pop
  #38
Old 06-17-2010, 10:14 AM
60RatRod's Avatar
60RatRod
60RatRod is offline
He's right thats why I suggested taking it in to a local shop, its a lot cheaper than getting s fine.
kcducttaper
1999 to 2016 Super Duty
04-21-2017 06:04 AM
ROBBINthaHOOD
06-16-2016 07:21 AM
edo488
07-05-2015 07:50 AM
Navigating180k
1997-2006 Expedition & Navigator
10-28-2012 10:11 PM
Bad78
06-11-2005 09:50 AM
Quick Reply: Why is A/C colder at idle?
