South Carolina Chapter Join Chapter, Leader: SC_Hoaty
Hey guys
Old 07-05-2009, 10:07 PM
Plums72's Avatar
Plums72
Plums72 is offline
Hey guys
Hey everyone, so i figured, since no one in the 80-86 forum, seems to know/care whats wrong with my truck i figured id ask my nice and amazing neighbors in SC.
https://www.ford-trucks.com/forums/8...-problems.html
theres the link to the original post, all the info and things ive done are in that thread. i apprecaite any help i can get, cause this thing is beginning to get on my nerves.
Yall have a good night.
Old 07-11-2009, 03:59 PM
FTE Trigger's Avatar
FTE Trigger
FTE Trigger is offline
I/We have a OBD1 reader... if you haven't had it read yet...
You know my nephew's '79 F100 (302) had a loping type of condition prior to changing plugs wires and the rotor button. After we re-did the wiring; we found out (from manual comparison) that the original set-up had a improper firing order.
Have you made sure all the plugs and wires are firing correctly? If you don't have one yet a spark checker is a good lit'l tool to have for this.
Old 07-12-2009, 03:17 AM
Plums72's Avatar
Plums72
Plums72 is offline
thanks trigger, actually, i got my exhaust fixed the other day while i had my chrom tips put on, and its running 15 times better than it was, still not quite rite, but i can actually keep a decent constant speed now...so im hoping that fixing the exhaust 100% and im gonna change the spark plugs, put new manifold gaskets on, and do a tune up of sorts and hopefully it will be good...
any way that my problem could have been a back pressure issue?
Old 07-15-2009, 02:51 AM
FTE Trigger
Unless you had a severe blockage and or crimp?
I figure if you had oversized pipes it would cause a loss of top-end?
How's the carb? By chance do you know which carb you have?...(just curious)
Old 07-15-2009, 04:36 AM
tin-man's Avatar
tin-man
tin-man is offline
I wish I could help Plums, but you are better off if I don't!!
Old 07-21-2009, 03:07 PM
Plums72's Avatar
Plums72
Plums72 is offline
its EFI trigger, and no, my pipes, if anything are undersized at 1.5 inches, im pumpin them up to 2 to 2.5 when i get the money....
and haha dave, thanks for the thought though
Old 09-13-2009, 01:13 AM
FTE Trigger
You still okay Anthony?
Mosouthernboy
02-03-2014 07:25 PM
BroncoLad
New Member Introductions
10-29-2013 02:58 PM
elliott000
1978 - 1996 Big Bronco
08-21-2013 07:08 PM
Edgethis
10-13-2011 04:24 AM
Redwing
1997 - 2003 F150
03-03-2009 10:12 AM
Quick Reply: Hey guys
