badass 57 ford
<P>thanks stephen67. like i said its a flaming river column and no drop but when i bolt the non dropped bracket under the dash it puts the column unable to get the correct angle out of the stock location. it will adventually go to a rack n pinion. do i have to cut some of the floor or am i just looking a it wrong</P>
Check out my albums. There is one called "57 Effie Steering Column" that shows how I did mine.
I cut my stock drop, lengthened it 1" with 1" x 1/8" steel bar stock (you can see where it is tack welded together while I experiment with it). I then used a die grinder to change the bottom part that wraps part way around the tube. The Flaming River column is larger diameter than the stocker. You will also have to make a floor mount plate to get things where you want them.
https://www.ford-trucks.com/user_gal...?userid=402689
Got any questions let me know!
SPark
SPark
