2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Information system chime
Old 07-02-2009, 12:04 PM
rod.d's Avatar
rod.d
rod.d is offline
We took our 08 Expy EL in for service last week to have the memory seats fixed, and since then the chimes that go with the information system warnings don't work anymore. For example, when you have a door partially open it will say "drivers door ajar" and it will play a chime, at least it used to. The key-in-ignition chime still works, but I believe that is a different circuit. Also, when we press the buttons to change the display on the information system, the beep doesn't work anymore. We are traveling and we took it to a local dealer and they basically said it wasn't supposed to do that, since they couldn't find it in the owners manual or service manuals. I guess we imagined it for 3 months before...
Any ideas on how to fix this? I don't know if there is a fuse for that, I guess I should check that. I have gone through the menus on the information system and there isn't a setting to turn it off/on. Thanks
Rod
Old 07-02-2009, 02:22 PM
bamp's Avatar
bamp
bamp is offline
I'd check the fuses first.
Old 07-02-2009, 03:29 PM
berry1234's Avatar
berry1234
berry1234 is offline
My 08 doesn't beep when you change the display. I will check and see if the door ajar makes it beep later tonight.
Old 07-02-2009, 03:35 PM
berry1234's Avatar
berry1234
Ok, checked. When you start the car you get seatbelt chime if not buckled. If a door is open when you start the car, no beep. If a door opens after the car is started you get a beep. No beep while changing display, etc. I think you are fine.
Old 07-02-2009, 03:55 PM
rod.d's Avatar
rod.d
rod.d is offline
That is part of the problem though, that when a door is ajar, with the warning message in the message center, there is no beep. Also when the lift gate it open and the truck is put into gear, it doesn't beep. The low fuel warning shows up, but no beep with it. I guess the problem is that we get the warning messages, but not the beeps that go with them.
Old 07-02-2009, 04:04 PM
berry1234's Avatar
berry1234
Hmm. Are you opening the doors after the car is started?
Old 07-03-2009, 06:18 PM
clearnetedm's Avatar
clearnetedm
clearnetedm is offline
Ya I think something has changed on your truck. A good test would be to open a door while in motion or in gear. There should certainly be an audible as well visual indication.
On our 08 if we are sitting in park and the passenger door opens there is just an visual light but if you place into gear then the audible tone comes. We don't get any tone when scrolling through the option menus thought.
Old 07-06-2009, 12:17 PM
bamp's Avatar
bamp
bamp is offline
^^^^ Yup, mine too!
rpmracing18
Electrical Systems/Wiring
10-15-2013 05:14 PM
1998Ranger25L153CID
1983 - 2012 Ranger & B-Series
08-22-2013 11:28 PM
sjclark11
06-13-2013 04:53 PM
spike552
1999 to 2016 Super Duty
02-14-2013 11:20 PM
imabaka
07-24-2011 12:51 PM
Quick Reply: Information system chime
