1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Clunking Noise when turning
Old 06-30-2009, 09:31 PM
jdevarie's Avatar
jdevarie
jdevarie is offline
Unhappy Clunking Noise when turning
Hello all and thanks for keeping up this great site. I have a 2000 F250 SD with the V10 engine. The problem that I am having with it as of late is that whenever I perform a full turn I hear some clunking coming from the front end. The clunking is similar to that heard from cars that use CV joints FWD but of course it sound more "manly"
Anyways, my truck has the full axle on front so I suppose it could be either the u-joint at the hub or the hub itself. I would like some pointers so I can acquire the required parts.
thanks in advance.
Jim
Old 06-30-2009, 09:45 PM
EXv10's Avatar
EXv10
EXv10 is offline
Mine did it too until I serviced the hubs. You should do that before you do anything else unless it's been done. It's probably the joints making the noise. There are posts in here on cleaning/greasing inner hub and locking hub. I made a post on the inner.
Old 06-30-2009, 09:51 PM
jdevarie's Avatar
jdevarie
jdevarie is offline
Thank you very much. That is nice to hear. I will research that. Hopefully it will stop raining up here (boston) so I can get it done :-)
regards,
jim
Old 06-30-2009, 11:12 PM
Robs06SuperDuty's Avatar
Robs06SuperDuty
Robs06SuperDuty is offline
my truck was doing it a few months ago, I had just assumed that I had the hubs engaged but I didnt, they might not have disengaged. it doesnt do it now.
Old 06-30-2009, 11:24 PM
EXv10's Avatar
EXv10
EXv10 is offline
If you get too much friction in the hubs they can spin the joints even though they are unlocked. After I did a greasing of the wheel and locking hubs it went away on mine.
Old 07-01-2009, 12:27 AM
Doubleubar's Avatar
Doubleubar
Doubleubar is offline
Another Source of a Clunk
While the hubs can provide the clunking noises, it is also possible for worn stabilizer bushings can also provide some lound clunking noises.
I have a 2000 F350 and had a clunking noise in the front end when I was making a left turn. I initially thought it could be one of the hubs but new bushings for the stabilizer bar eliminated the noise.
If you service the hubs and still have a clunk I would check the bushings on the drop links and those connecting the bar to the front axle.
Glenn
Old 07-01-2009, 11:51 AM
Powerstrokin_350's Avatar
Powerstrokin_350
Powerstrokin_350 is offline
I have the same problem as well. New ball joints, new wheel bearing and hub assemblies on both sides, new warn non auto hubs, and my noise is more of a growl, not a clunk. only does it turning left and can feel it in the steering wheel. still maybe the stabilizer bar?
Old 07-01-2009, 12:04 PM
Powerstrokin_350
Oh, and its lifted if that changes anything
Old 07-01-2009, 12:25 PM
krewat's Avatar
krewat
krewat is offline
Site Administrator
Sounds like the axles are turning. Either the hubs are locked, stuck, or the needle bearings (inner spindle bearing) is dry and rotating the axle even when the hubs are unlocked.
Old 07-01-2009, 12:27 PM
senix's Avatar
senix
senix is offline
Received 1,418 Likes on 1,013 Posts
If you find you need to do some maintance here is a great website to help:
http://www.guzzle7pt3.com/index.php
Old 08-18-2009, 08:27 PM
jdevarie's Avatar
jdevarie
jdevarie is offline
thank you
Thank you all for the help. Will get this done shortly!!!!
Old 08-22-2009, 11:16 AM
maverick5.0's Avatar
maverick5.0
maverick5.0 is offline
there is also a service bulletin on the drive-shaft clunk noise and to use teflon grease on the transmision output shaft so the drive-shaft can slide fore and aft... good PM since you will be wrenching away...good luck...-mel-
Old 01-09-2014, 01:14 PM
EricPero's Avatar
EricPero
EricPero is offline
Do you have the service bulletin #? I am experiencing bad clunking when turning the wheel in 4x4 at slow speeds - new ball joints, new u-joints in axle shafts and new wheel hubs.
Old 01-11-2014, 10:46 AM
galaxie460's Avatar
galaxie460
galaxie460 is offline
My clunk was the sway bar bushings and links, it sounded like it was right under my left foot, did it when I turned into a driveway then everytime you hit a bump.
Old 01-11-2014, 03:51 PM
krewat's Avatar
krewat
krewat is offline
Site Administrator
Very old thread - 5 years
That is somewhat normal. These trucks do not use "CV" joints in the front axles, so when in 4x4, you WILL hear some slap back and forth with the wheels turned.
giorgio.fo
05-16-2017 08:21 PM
Tugly
08-15-2016 10:58 AM
mj_355
01-26-2016 08:03 PM
stanimals2
1997 - 2003 F150
01-05-2014 06:54 AM
95f150
03-10-2004 07:01 PM
Quick Reply: Clunking Noise when turning
