Go Back   Ford Truck Enthusiasts Forums > Misc. > Offroad and 4x4
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Offroad and 4x4 SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 06-28-2009, 10:06 PM
mando jake's Avatar
mando jake mando jake is offline
1988 Ford F-250
mando jake is starting off with a positive reputation.
Question What is this bracket on my 91 D60?
I'm getting ready to rotate my knuckles on my D60. What is this bracket that is in the way?
__________________
Leitchfield,ky 42754 FTE Kentucky Chapter member mando_jake@yahoo.com
88 F250 4x4 EFI 460 ZF5 4.10 gears limited slip.
  #2 (permalink)
Old 06-29-2009, 01:12 AM
75F350's Avatar
75F350 75F350 is online now
1973 Ford F-100
My Garage
75F350 has a great reputation on FTE. 75F350 has a great reputation on FTE. 75F350 has a great reputation on FTE. 75F350 has a great reputation on FTE. 75F350 has a great reputation on FTE. 75F350 has a great reputation on FTE.
That appears to be a sway bar bracket
  #3 (permalink)
Old 06-30-2009, 11:24 PM
RawPower's Avatar
RawPower RawPower is offline
RawPower has a very good reputation on FTE. RawPower has a very good reputation on FTE. RawPower has a very good reputation on FTE. RawPower has a very good reputation on FTE.
Quote:
x2... but you're missing the sway bar
  #4 (permalink)
Old 07-01-2009, 12:17 AM
75F350's Avatar
1973 Ford F-100
My Garage
Have you actually ever knocked a "C" off of one of these things before? Is this your first time rotating the c's? Not an easy thing to do. The fit between the tube and the "C" is tight, I mean real tight.
I would be interested in seeing the jig that you have made to maintian the correct replationship and strightness bewteen the "C's".
I only ask because I have seen several axles ruined this way........
  #5 (permalink)
Old 07-01-2009, 03:22 PM
hav24wheel's Avatar
hav24wheel hav24wheel is online now
hav24wheel is gaining momentum as a positive member of FTE.
why do you need to turn them anyways? your not lifting it that high are you?
__________________
my supermotors page http://www.supermotors.net/users/hav24wheel
78,85,92 Ford
Just bought a 94 F-150
  #6 (permalink)
Old 07-01-2009, 10:01 PM
mando jake's Avatar
1988 Ford F-250
6 inches maybe 8 for now. But its out of the truck now and it would make it easier.
__________________
  #7 (permalink)
Old 07-01-2009, 10:54 PM
mando jake's Avatar
1988 Ford F-250
I've never done it before. Here's my plan:
1. Get rid of sway bar bracket. Grind out weld around C's.
2. Use a digital protractor and reference the pinion area to the back sides of the kingpins individually in case they are inconsistant from side to side. I'm shooting for 4* offset from factory.
3. I see no reason to knock the C all the way off. I'm gonna try to free up the welds and rotate it without pulling it all the way off.
4. Reweld C's and tack on 4* spring pad wedge
Like I said, I've never done this before, but I've done a lot of heavy duty fabrication at work. Before I transferred to the Fab. Dept. I was a machinist. I see no reason that I couldn't manage this, but I am open to suggestions if they stem from actual experience.
__________________
  #8 (permalink)
Old 07-02-2009, 02:39 AM
75F350's Avatar
1973 Ford F-100
My Garage
For that small amount, I would just consider wedging the spring perch. I mean, to me its not worht the effort and potential failure.
You have to cinsider the amount of movement that the "C's" can potentialy move.
Im not a bad fabricator, and I thought about this myself. I removed everything, and machined the tubes, and "C's", only to find some discrepancies in my set up, and ended up sending my junk to Dynatrac to complete. Could I have completed it? Maybe, but I was not willing to take the chance.
I had nothing to make a reasonable reference to, and without accurate data, there was no way to verify that what I had was gonna work. I hate doint things twice, so I opted to have it done at a reliable place.
  #9 (permalink)
Old 07-02-2009, 09:04 AM
hav24wheel's Avatar
i would not go through all the work to turn the "C"s for only 4*. i have 8 inches of suspension lift on my pickup. i just turned the axle so the pinion angle looked good. it runs down the road nice.. From what i have read about turning the "C"s, its a pain to get them to move..
__________________
78,85,92 Ford
  #10 (permalink)
Old 07-02-2009, 05:51 PM
mando jake's Avatar
1988 Ford F-250
Quote:
Do you recall about how much you rotated the axle for 8 inches?
Did you use spring pad wedges, or did you use drop hangers in the front?
Did it move the front axle back in the wheel opening any?
__________________
  #11 (permalink)
Old 07-02-2009, 06:00 PM
hav24wheel's Avatar
Well I used radius arns and coils. So its hard to say. I put it under there, hooked up the driveshaft and set the pinion angle. But I'm sure on yours you should get away with some shims.
__________________
78,85,92 Ford
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
