Can I run a Quadrajet?
on
Hi,
I was checking my fuel economy (1986 F-250, C-6, 351, 3.54 gears) and found I am getting 10 mpg. I am guessing my Holley is in need of a rebuild. I have had a lot of experience with GM's. I have run Holleys, Carters, Edelbrocks, and Quadrajets. I like the Quadrajets the most by far. I was wondering how hard it would be to mount a Quadrajet onto the engine, and what it would entail? Has anyone else done this before?
Thanks,
Nick
Thanks,
Nick
You are putting a totally different carb on your engine. It's not going to bolt on and run without some fiddling, and your emissions system is probably not going to hook up and run properly. In other words, the EGR might be out the window along with the other emissions components.
on
on
Thanks guys, sorry about the questions, I am a little gun shy when it comes to Holleys. I do not trust them too much. I ended up ordering a rebuild kit for the Holley and will try that first. I was curious, this has the sealed idle mixture screws. How can I bypass that, and make them adjustable again?
wwbenner
13
11-22-2013 06:40 PM
73F100*8Mile
21
01-15-2008 06:18 PM
LetsRock
08-28-2005 12:10 AM
quarternary
12-21-2004 09:57 AM
