can i put old oil,atf and gear lube in my 6.9?
Old 06-14-2009, 05:51 PM
bill11012's Avatar
bill11012
bill11012 is offline
Modular motor junkie
Can i put old motor oil,atf ,frying oil and gear lube in my 6.9? If so, how do
I filter it?Do I need to mix it with fuel, or can I run it strait?
sorry but I am a to this hole alternative diesel fuel thing.
Old 06-23-2009, 10:00 AM
Brown Falcon's Avatar
Brown Falcon
Brown Falcon is offline
ATF yes, fry oil needs to be filtered and heated and would need a WVO conversion... I wouldn't put motor oil or gear lube in it
Old 06-24-2009, 08:52 AM
bill11012's Avatar
bill11012
How do i do the WVO conversion?
Old 06-24-2009, 09:02 AM
Brown Falcon
don't know all the details but...
You filter waste veggie oil and then use one of your tanks for veggie and one for petro diesel. The veggie oil needs a heater to warm it up and make it thinner and easier to burn/pump.
You start the truck on petro diesel, then switch tanks over to veggie once it's warm, then you need to switch back to petro diesel the last couple miles to flush out the veggie oil.
There are some other things you need... but that's the basics. You can buy kits to do it.
Old 06-24-2009, 10:29 AM
fabmandelux's Avatar
fabmandelux
fabmandelux is offline
Try this sub-forum's sponser: http://www.vegistroke.com/
They have the best system IMMHO...............
Old 06-24-2009, 10:35 AM
bill11012's Avatar
bill11012
I will try to get details there.
Old 06-26-2009, 07:13 AM
kirkharrod's Avatar
kirkharrod
kirkharrod is offline
Greasin' is not for everyone.
IHbase
02-03-2013 04:46 PM
MonatheGrona94
Oil & Lubrication
06-06-2007 09:41 AM
BCO2JCO
04-09-2007 09:55 PM
diesel-lady
04-25-2004 11:58 AM
mcbob
12-22-2003 12:23 PM
Quick Reply: can i put old oil,atf and gear lube in my 6.9?
