Weird question about gearing
#32
#34
#35
Many years ago farmers would take old trucks and install or adapt tractor gear housings on the chassis. In 1971 I helped haul out a Model A that had been transformed during WW2 and was used until the 1960s. We actually got the thing running and the owners used it for hay rides and to move stuff around the yard. It had an aux trans mounted on the rear of the original gear box and @ 2 mph hauled out a IH tractor and combine after the "cornbinders" injector pump let go.
I think the engine was the 122 CID flat four which was an improved Model T engine with a Frontenac high performance kit. The Model A might have been a police car at one time since the kit was used by many police departments.
old man rambling
sorry
rikard
old man rambling
sorry
rikard
#37
Gear reduction would be limited by the strength of the drive axle.
When in transfercase low,first gear and 4.10 axle ratio with the 302 at torque peak-there is about 11702 foot pounds of torque at the rear axle. Offroad conditions-such as one good jerk of the throttle or getting a drive axle into the air could cause very expensive axle damage-even in a factory equipped truck such as my own.
270 ( @ 2400 RPM torque peak 302 ) x 2.69 (low range) x 3.93 (first gear M5R2) x 4.10 (8.8 4.10 axle ratio) = 11,702.871 foot pounds.
43.34 to one gear reduction overall .
#38
With that said, I try to be careful when I make a turn, but sometimes I have to floor it at an angle. So far all it's done is bark the tires and jerk the truck (minor jerk, but you feel it).
Hard to believe nobody makes a realiable selectable locker though?
#40
77beater150
03-11-2014 12:14 PM
cmpd1781
23
07-27-2012 07:02 PM
