Anyone Ever Change an Oil Pan Gasket Without Lifting the Engine?
That stuff is the bomb. Found many a leaks on all type of vehicles over the years. You'll be surprised on where the original location is.
Sorry, my pan is showing signs of rust and it would be nice to get a new pan that I have coated but I don't want to take it out at this time and the tech who works on the side for me can't do something like that in an evening and not get into trouble. Small jobs like injectors and turbos he can do on shop nights because the boss has gone home. Leaving an engine out to dry the RTV takes too long and is too obvious. The international shop will not do it since I have an SUV and not a truck.
I don't believe you. Why don't you take my pan out and prove it.
If you're just starting to show rust, why not use Por 15 or something and try to save it?
I will have to do that this summer again. I did it last year but it has rusted at different spots. Also I saw someone on either this site or another using the sealant that they use for bedliners to rust proof it and if he would prove it, by taking out my pan, I'd be real happy to stick that lined pan in.
I dont see exactly what your getting at here? I have done over 25 oil pans on 444e and they are the same engine. None have leaked again the oldest one being a 1997. As far as international not being able to work on your SUV im sorry that your local dealer will not work on it but our dealer will do fords just not warrenty its against policy between ford and international. We get quite a few fords that come in and anyone in my area is more than welcome to come in with there issues. Good business for the company. If what your talking about is rusting of the pan then thats something specific to ford not international. The pans are made of a generic steel and its not just the 7.3s its 351s,460s,300s, etc that all rust out. When i do a pan at work i normally put a new on on since its off anyways.
It's weird but they would work on it if I brought in an F250 but because it is an Excursion, they won't.
I thought the Ford gray sealant is the international one? Seems like Ford rebadges the international stuff.,
#28
Ok i got what ya mean now. haha. Yes you are correct beng that ford does just rebadge th rtv. Most of the stuff that ford sells is just repacked international stuff. Except the few things that makes the powerstroke different such as the fuel lines going to head from housing. Thats odd that they wont work on it though. If you could bring it to us we could fix it up for you.
#29
I finally found something to stop my leak... at least for now...
My leak was at the front of the pan gasket, under the harmonic balancer area. I really didn't want to pull the engine, so I've tried many different thing to stop the leak in the last few weeks.
Nothing seamed to work, until my buddy recommended "the right stuff". I put some on (smeared it on with my finger) Tuesday night and it hasn't leaked since (I've put about 300 miles on it since). I'm keeping my fingers crossed that will solve the problem.
#30
