1989 F250 4WD 351 to 7.3 IDI fuel line question
In the process of converting to diesel from 351. Starting on fuel system conversion. In regard to the fuel lines for fuel tanks, have removed gas fuel pump, fuel filter and fuel reservoir. Can I use the remaining existing fuel lines and connect to the 6 port fuel tank selector valve or do I have to change all fuel lines from tanks to 6 port fuel tank selector valve? If I have to change the fuel lines out from the tanks what is the best size of fuel line to use? Is using a rubber or synthetic type fuel line acceptable or do I have to use carbon steel and do a complete replacement?
Mhintlian
12-03-2017 10:35 PM
Chicken_Fried
26
11-08-2009 08:33 PM
