Removing AC pulley
Old 06-30-2009, 11:21 AM
dognip666's Avatar
dognip666
dognip666 is offline
Removing AC pulley
So I've got a 95' F-150 w/ 300 engine - the A/C has been nice and cold right along. A few days ago the A/C pulley started chattering and you could smell it burning up so I shut it off and limped along with this worsening rattle. I bought a shorter belt to bypass the A/C but it's pulley protrudes into the path of the shorter belt just a bit - can I remove the pulley from the compressor or does the whole unit need to be removed? I took the clutch off but I can't see what else holds the pulley to compressor. Any info is much appreciated.
Evan J. West
Old 06-30-2009, 03:23 PM
lsrx101's Avatar
lsrx101
lsrx101 is offline
Look close. There is a snap ring around the compressor snout to hold the pulley in place. Remove the snap ring and the pulley will slide off with a little help from a screwdriver.
If you need to remove the clutch coil, just pry it off with a big screwdriver working from side to side.
Old 07-04-2009, 10:17 AM
tboss619's Avatar
tboss619
tboss619 is offline
OPPS I placed a post in the wrong place and I need to have moved to a/c repair can one of you moderators move it for me I put it in aerostar It title is clutch air- gap adjustment tks I will try harded to get my post in the rite place terry
BadDogKuzz
13
03-03-2016 07:47 PM
Whitey Ford
12-30-2013 07:47 PM
dieselfumes12
1999 to 2016 Super Duty
12-18-2012 07:52 PM
Silverback
16
08-08-2005 08:58 PM
BIG DADDY 51
05-31-2004 07:41 AM
Quick Reply: Removing AC pulley
