unrealistic expectation?
I expect for the truck to go when you press the go pedal. When the truck is cold, it has little power. If in neutral I floor the truck it only revs to about 2K, then slowly climbs, When in gear it is almost scary. It will not get into traffic without creating problems.
After about 20 min. It is running great, and has the normal turbo lag.
Dealer has changed the turbo, and worked on it. They thought that they had it fixed. Now it is better, but still doing the same thing.
The truck's engine is completely stock. And I have no desire to chip it.
Going to take it back again, any ideas on what can cause this?
