hi all, i have a 97 f250 heavy dudy 5.8L (old body style) with the 8 lug pattern. my question is, is there a rear drum to disc conversion kit for my truck? cant seem to find one and its almost time to do the rear brake, and would hate to use drums again!
still the only kit i could find, little pricy at 750 or so, kinda sceptical about using old cadillac eldarado calipers, but i am sure its still 5x better than the crappy drums
clearance issues maybe? if you look at the kit it just looks like swiss cheese flat stock. looks like it calliper bracket can be used with other kits. could prob. make one yourself if you could cut that thick of flat stock?
You'd probably have to use the bolt-on calipers from whenever they switched from the pins, but I don't see why they couldn't cram it in there. If I had a plasma cutter, I've got the stock. Not going to burn up a hundred Sawzall blades cutting out brackets just to try it.
