Radio replacement 1985 F150
Well, the boys radio doesnt change stations, old manual **** type, and he wants to be able to play MP3s
What I have when I take it apart appears to be a 4 inch by 1 and 7/8 inch hole for the face of the radio, two ***** about 6 and 3/4 inches apart.
there is a metal bracket behind the bezel that fits this in, though the bezel is just an open square hole and the blank space is filled by the bracket with the radio in it.
I am thinking I either need to find a radio that has the posts and will mount in the existing bracket or I can mount a DIN type radio in this, but would have to cut the hole in the metal mounting bracket bigger to do so.
Any advice would be appreciated.
Dave
Dave
Bezel is a big open square, 7 in. by 2.25 in. like the open ones you have for sale in the sale/trade thread. The single DIN faceplate on the existing radio is not tall enough to cover the hole, but it is wide enough.
Thanks for the info on the strap, we used to get those with the mounting kits in the old days.
Will have to figure out how to strap it in tight since the boy likes to run the trails around here and I figure there is no way the plastic faceplate is gonna hold without cracking if there is no additional support.
You may have to use something like this:
Universal Trim Ring 1/2-inch, chassis size E at Crutchfield.com
Got the radio in, but got something hooked up wrong or did not get a good connection. Radio works fine except it wont remember the preset stations. Figure I got the constant power wire hooked to non-constant power or did not get a good connection. I used a meter to check for power when we hooked her up, and the radio does not stay on when the ignition is off. Must have a bad connection is all I can figure. going to tear the dash off again and see what we screwed up.
d
d
gbakman
10-19-2016 03:44 PM
AZ_Ford_Guy
09-10-2012 11:08 PM
Rogue_Wulff
19
02-17-2011 07:07 AM
first today
44
04-28-2009 10:04 PM
