Red Head Steering gear box installed
#391
I have a lifetime warranty on mine from the parts store. Damned thing went loose after 2 months. 8 hours of prying to get the old one out - not something I want to do again. I want something that will not wear, and the RedHead with bearings seems like the answer. But I'm in Cali.... and shipping sucks.
#392
It's pretty much the same shipping, I think the place is in WA so it would be cheaper for you than me. It's shipped large flat rate with USPS, so it can't be more than $17 or so to send your old one back. The whole process was pretty easy for me, and they even gave me a military discount. I would use them again. It's a nice box.
#393
#394
I've had one reman from the Oreillys store that got sloppy in about 16 months...After that aggravation I got a redhead...that was 10 years ago and it is still perfectly tight....I got a newer van and did the same replacement with a redhead....The difference between the worn out originals, reman and what redhead does is significant in my experience.....
I am local to them and have been in their plant (no shipping but sales tax)...they do a LOT of boxes a month and are pretty proud of their work....
Cheers
#395
2003 2WD. Lifted. The only good thing about the probelms the lift causes is I don't have to jack it up.
Getting that big arm off was a chore. Bent two pullers. Had to pry and pull to remove it. tightening the nut had me twisting on the ground beneath the beast. I now have a C6-7 disc injury that causes neck pain in situations like that. Working on my back is now involves major thought.
But, maybe y'all can offer some advice on getting things manipulated a bit easier.
#396
I have an 05 4wd and my Red Head feels like there is little power assist. Your box will not be the same , and the guys with 99 to 04 4wd trucks really like there Red head.
When I did mine I took the box off with the arm still on.
#397
Just installed redhead steering box
Also replaced lower steering shaft with Borgeson with vibration damper and found out that the drag link wasn't right so I put a drop down drag link fit like a glove 1977 f250 XLT RANGER 4inch lift 35 inch with high performance 390 Fe
#399
#400
You're welcome. I was actually going to update this thread with my latest mod. I installed a filter on the return line. Can't say it was my idea.
https://www.ford-trucks.com/forums/8...ing-flush.html
Attachment 16904
Attachment 16904
#402
#403
