Red Head Steering gear box installed - Page 27 - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > 1999 to 2016 Super Duty
Reload this Page >
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
  #391
Old 10-11-2015, 10:58 AM
carlspeed's Avatar
carlspeed
carlspeed is offline
carlspeed is starting off with a positive reputation.
Originally Posted by 8 burnin 2 turnin View Post
I have a lifetime warranty on mine from the parts store. Damned thing went loose after 2 months. 8 hours of prying to get the old one out - not something I want to do again. I want something that will not wear, and the RedHead with bearings seems like the answer. But I'm in Cali.... and shipping sucks.
It's pretty much the same shipping, I think the place is in WA so it would be cheaper for you than me. It's shipped large flat rate with USPS, so it can't be more than $17 or so to send your old one back. The whole process was pretty easy for me, and they even gave me a military discount. I would use them again. It's a nice box.
  #392
Old 10-11-2015, 09:30 PM
8 burnin 2 turnin
8 burnin 2 turnin is offline
8 burnin 2 turnin is starting off with a positive reputation.
Seriously? That's good news. I'll have to rethink this. I'm injured, but maybe it would be worth the pain and aggravation.
  #393
Old 10-12-2015, 08:52 AM
CPB1's Avatar
CPB1
CPB1 is offline
CPB1 is a splendid one to beholdCPB1 is a splendid one to beholdCPB1 is a splendid one to beholdCPB1 is a splendid one to beholdCPB1 is a splendid one to beholdCPB1 is a splendid one to behold
What year truck are you working on?
  #394
Old 10-12-2015, 09:34 AM
moorefc
moorefc is offline
moorefc is starting off with a positive reputation.
I've had one reman from the Oreillys store that got sloppy in about 16 months...After that aggravation I got a redhead...that was 10 years ago and it is still perfectly tight....I got a newer van and did the same replacement with a redhead....The difference between the worn out originals, reman and what redhead does is significant in my experience.....
I am local to them and have been in their plant (no shipping but sales tax)...they do a LOT of boxes a month and are pretty proud of their work....
Cheers
  #395
Old 10-12-2015, 10:32 AM
8 burnin 2 turnin
2003 2WD. Lifted. The only good thing about the probelms the lift causes is I don't have to jack it up.
Getting that big arm off was a chore. Bent two pullers. Had to pry and pull to remove it. tightening the nut had me twisting on the ground beneath the beast. I now have a C6-7 disc injury that causes neck pain in situations like that. Working on my back is now involves major thought.
But, maybe y'all can offer some advice on getting things manipulated a bit easier.
  #396
Old 10-12-2015, 09:09 PM
CPB1's Avatar
CPB1
CPB1 is offline
02 2wd Wow OK, caught me off guard on that one.
I have an 05 4wd and my Red Head feels like there is little power assist. Your box will not be the same , and the guys with 99 to 04 4wd trucks really like there Red head.
When I did mine I took the box off with the arm still on.
  #397
Old 11-23-2015, 06:10 AM
Angelo Zani
Angelo Zani is offline
Angelo Zani is starting off with a positive reputation.
Just installed redhead steering box
Also replaced lower steering shaft with Borgeson with vibration damper and found out that the drag link wasn't right so I put a drop down drag link fit like a glove 1977 f250 XLT RANGER 4inch lift 35 inch with high performance 390 Fe
  #398
Old 11-24-2015, 07:24 AM
Monster-4's Avatar
Monster-4
Monster-4 is offline
Who? Me?
Monster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud of
Nice looking truck!
  #399
Old 11-24-2015, 07:39 AM
Angelo Zani
Originally Posted by Monster-4 View Post
Nice looking truck!
thxs just crawled from under nieth thetruck to find out I need to order shocks not to many make for this year w/a four inch lift was trying to get bilsteins but they don't go that far back ended up going with skyjacker nitro 8000
  #400
Old 11-24-2015, 07:42 AM
Angelo Zani
You're welcome. I was actually going to update this thread with my latest mod. I installed a filter on the return line. Can't say it was my idea.
https://www.ford-trucks.com/forums/8...ing-flush.html
Attachment 16904
best thing you could have done
  #401
Old 11-24-2015, 11:45 PM
scld1354
scld1354 is offline
scld1354 is starting off with a positive reputation.
Monster-4, I haven't read through all 27 pages but I'm curious how the red head box has held up. Also, are you running a lift and bigger tires or all stock?
Thanks!
  #402
Old 11-25-2015, 06:28 AM
Monster-4's Avatar
Monster-4
Who? Me?
I am running slightly larger tires 285 vs 265 stock but no lift. So far the steering box has zero slop and no leaks.
I am developing some slop in the steering but that is from the ball joint at the end of the drag link that attaches to the pitman arm.
  #403
Old 12-26-2016, 08:26 PM
darkjedi351's Avatar
darkjedi351
darkjedi351 is offline
darkjedi351 is gaining momentum as a positive member of FTE.darkjedi351 is gaining momentum as a positive member of FTE.
I know this is a old topic but I just wanted to say thanks for the write up. I just finished installing a red head gear box along with a steering pump and other parts. great write up. my steering feels tighter and more responsive than my 2000 f250 did new.
  #404
Old 12-28-2016, 06:53 AM
Monster-4's Avatar
Monster-4
Who? Me?
No problem. Glad it helped.
  #405
Old 02-05-2017, 09:28 AM
buddysharp
buddysharp is offline
buddysharp is starting off with a positive reputation.
Years later, great write up. thank you for taking the time to do this.
Quick Reply: Red Head Steering gear box installed
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
