1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Red Head Steering gear box installed
Old 09-28-2010, 05:17 PM
EXv10's Avatar
EXv10
EXv10 is offline
Originally Posted by Boris2000
I guess you would have to be a farm service mechanic, in WI. to use that phrase. lol
I thought it was a southern thing
  #92
Old 11-04-2010, 05:57 AM
LilmizPowerStroke's Avatar
LilmizPowerStroke
LilmizPowerStroke is offline
Thumbs up Thanks for this article/site
Just wanted to say thanks for this article and forum, we read this thread, changed the steering gearbox to the Red Head on our 2000 F250 and it drives like a brand new truck.
  #93
Old 11-04-2010, 01:06 PM
sscarboro's Avatar
sscarboro
sscarboro is offline
Originally Posted by EXv10
And some advice for you:
3; That's not true at all. Nobody is going to keep buying garbage.
Then why is WallMart still in business?? LOL
  #94
Old 11-04-2010, 07:00 PM
T8R's Avatar
T8R
T8R is offline
The guys at Redhead really know their stuff... twice I've thought I might have had an issue... and called them up. Both times they were polite about being confident of their own workmanship, told me which other parts to check first ... and both times they've been right... (turns out... eating a bushing was my own fault...)
Very friendly and their customer service is top notch.
  #95
Old 11-04-2010, 07:40 PM
bill11012's Avatar
bill11012
bill11012 is offline
Modular motor junkie
Originally Posted by Greg B
A-1 Cardone is remanufactured to OEM standards and Redhead is supposed to be better than OEM specs. Nothing wrong with A-1. But it's like a blueprinted engine compared with a new engine from Ford. Redhead should have tighter tolerances than OEM, hence the higher price.
A1 Cardone is garbage. I ate through 6 of their steering gears in less than 30K miles. They would start off good and get looser and looser until they were unsafe.
  #96
Old 11-04-2010, 08:16 PM
Pinky Demon's Avatar
Pinky Demon
Pinky Demon is offline
My 02 with RedHead and dual Pro Comp Steering Stabs, steers better than both an 09 F-250 and a 2011 F-550 that I have driven.
  #97
Old 11-04-2010, 09:39 PM
EXv10's Avatar
EXv10
EXv10 is offline
Nothing hi tech at Walmart, including everybody in the store (except me when I am there).
  #98
Old 11-04-2010, 09:41 PM
EXv10's Avatar
EXv10
EXv10 is offline
How can you go through 6 steering boxes in 30k miles?
  #99
Old 11-05-2010, 09:04 AM
bill11012's Avatar
bill11012
They would start off fine and within a few thousand miles be so loose I could not stay in my lane. A1 would exchange them and I would do it all again. After the last one was leaking from the time I put it in becuase the seal was installed wrong, they gave me cash back on the box and the core.
The Redhead fixed it for good and made it better than when it was new.
The A1s are nothing close to factory spec.
  #100
Old 12-14-2010, 08:54 PM
martin123456789's Avatar
martin123456789
martin123456789 is offline
Originally Posted by Monster-4
I scare myself all the time when I use logic!
To add an update to this thread:
After 5,000 miles and 8 months I'm still in love with the Red Head Steering box. No slop has developed and it still handles great. I've gotten many compliments from people who have drove my truck on how well is handles and steers. I'm just glad I can go down the road without feeling like a drunken sailor.
I do have an on center to near on center memory steering issue but I don't think it's related in any way to the steering box. I have an idea given to me by a trusted local alignment shop to eliminate that issue. I plan on trying it when the weather warms up and I can tear into it. If it works I'll post my results otherwise I'll conveniently forget that I said anything at all.
Seriously.. the steering gear, if it is the cause to my wandering, this **** **** ****** *** ***** is dangerous.
I have about 2 inches of play in my steering wheel before it does anything.
Having difficulty staying in your lane with dry pavement is one thing, but when you're driving in a winter blizzard and the slightest steer will put you in the ditch...... then a curve is up ahead with no sight of pavement while a toyota tercel is easily passing you...
I've had the steering gear for 2 weeks now, just got to get some courage to install that in -4F weather.. :S and hopefully I won't have my life flash before my eyes while trying to keep my truck on the road.
Btw, my truck only has 70K miles.
  #101
Old 12-14-2010, 09:26 PM
GUNNERDOG's Avatar
GUNNERDOG
GUNNERDOG is offline
the install is REALLY easy except.... getting that pitman arm off can be difficult...
i had to take it to the shop and have it pressed out.
  #102
Old 12-14-2010, 10:11 PM
martin123456789
Yeah, that's what I'm scared off.. I have a puller but from what I read, that might not be enough .. and chances are I might break the puller :S
  #103
Old 12-14-2010, 10:49 PM
GUNNERDOG's Avatar
GUNNERDOG
I broke two, and almost lost a finger when the second one let go... A press is the way to go if it is all seized on there, or just buy a new pitman arm for $50...
  #104
Old 12-15-2010, 08:56 AM
martin123456789
The hard part is taking it off the drag link or the steering gear itself?
  #105
Old 12-15-2010, 09:07 AM
GUNNERDOG's Avatar
GUNNERDOG
removing the pitman arm from the steering gear is what gave me trouble. the drag link cam off the pitman arm easily.
Quick Reply: Red Head Steering gear box installed
