2 speed wipers or not
My 2 speed wipers are only working at one speed, very fast. They also do not park back at the bottom they kind of coast to a stop depending on when you turn them off. Where do I start trouble shooting this. I am hoping to do the weather stripping, fix the chip in the windshield and work out this wiper thing so I can drive to work on Thurs. You guys have been a god sent so far on my other problems and I just love working on this truck. Thanks again.
Cbass
Cbass
Ok for a littlel of the particulars, your profile says you have a 58 F-100 so we all know you have electric wipers and they are 12 volt....Or they should be.
Question is do you have the stock wipers and switch? And one question further, if not, is the switch the one made for the motor you do have. If it's the stock or a matched set wiper/switch combo, chances are very good it's just a wiring disjoint.
Let me know...in the mean time ....Bump to top!
Well the thing you want to look for are the part numbers. Then we can figure out what you have and what you might need. On the wiring, It's a matter of finding the circuit drawing for the motor and switch that you have and making sure they are connected correctly.
There should be at least three wires: low speed; high speed, and park. There should be a fourth terminal on the switch to allow for power to come in. So we just need to make sure your power in isn't hooked to the low speed terminal of the switch, etc.
So, I guess we start with the part numbers.
Of course the plate has been rubbed to the point that I think I can make out the work American but not even possitive of that. It does look exactly like the one in the owners manual so I will try going through the wiring to make sure it isnt just connected wrong. Will let you know what I find. Thanks
Cbass
Cbass
One of the wires was disconnected, once reconnected it worked like a charm. I know that these are older vehicles so when they say that the wipers will park does that just mean that they stop when you turn them off or are they supposed to work like newer model vehicles and return to the bottom possition?
definatly not doing that, they just kind of stop where ever I turn them off. Where do I start with this fix, I think when I was looking at the wiring in the manual I say a diagram that showed a Parking something or other. Should I pull the wiper motor and see if the inside looks like the diagram shows it? or is there a easier fix?
