You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
so i get a pretty clean 92 F-150 that sat for a year... i get it running ok, i tag it and my wife decides shes gonna get it inspected while im at work, Yea well if only i knew... It FAILED it wasnt ready... SO now idk what to do ... i dont have the $ get the things it needs fixed.. Anyone have any ideas? id really appreciate it
Find a friendly service station that does NJ Inspections and hope for the best.
What items did they fail the truck on? Emissions, brakes, suspension? You have 45 days to correct problems, if not ,you can bring it back and get additional 45 days, you can still use truck.
"Steering Lash". WOW. The last time I had steering lash checked was on my '87 3/4 ton when I had stability testing done in Lodi for the 7" of lift I had installed...
__________________
Chris
2008 F350SD CC PSD Short Bed
2000 F350SD CC PSD Dually - Sold
1995 F350 CC PSD Long Bed - Traded-In
1987 F250 STD Cab - Gasser - Sold
i failed for Emissions, Steering lash, rear brakes outta adjustment, Front gas cap, Headlight, ..... i fixed the Headlight, gas cap,
Steering lash is probably excessive play,maybe bad tie-rods or steering arm, emissions can be several different items, on your printout, does it show high hc or co readings?
