speedometer needle
speedometer needle
Hi, sorry to be jumping right in with a question, I've actually found alot of answers just searching around here but this one I can't lock down. I've had issues with my speedometer needle, and after I replaced the speedometer cable it just called it quits. I'm thinking, I need to start searching the internet for a whole new unit, but it would be nice to hear if anyone has been able to replace just the needle, and the best place to buy a cable that actually fits right. Thanks. Oh, guess I should mention, it's a '49 pickup.
Last edited by barked-knuckles; 05-25-2009 at 11:06 PM. Reason: left off something
First, welcome to the board, second, questions are one of the main reasons for this board so don't apologize for jumping in with a question.
One of the main causes I've found for inoperative speedometers is lubrication. If the cable isn't properly lubricated it can just stop working or act erratically. Improper lubricant can cause a lot of problems too. Did you use speedometer lubricant, which is just powdered graphite? If not make sure the cable and casing is clean, reinstall the casing, insert graphite and then the cable and see how it works.
Wow, hadn't heard about that bit of maintenance. The initial problem is that the needle started flapping around, then sort of popped away from the face of the speedometer, like it was sprung. There definitely seems to be a streched-out spring attached to it, and it's laying at the bottom of the unit. (It's pulled out, as I've been looking for a way to replace the needle)
1951/52 Speedometer
Does anyone know if a speedometer head or the speedometer head parts themselves for a 1951/52 will work on 1948/50's?
C9TZ17255C .. Speedometer Head / C9TZ-17255-C replaced 1C-17255-A / Obsolete
Fits: 1951/52 All Trucks / 1957/77 P Series Parcel Delivery
KINSEL L/M in Beaumont TX has EIGHT: 800-816-2894.
PARTS INTERNATIONAL in Farmers Branch TX has EIGHT: 888-727-0418.
BOB ALLEN FORD in Overland Park KS has FIVE: 800-676-0675.
GREEN SALES COMPANY in Cincinnati OH has ONE: 800-543-4959.
Kinsel L/M will prolly be the cheapest.
A jumping speedo needle can be caused by a dry speedometer cable core or a partially stripped DRIVEN gear that fits onto the end of the cable.
Inside the speedometer cable housing is a woven steel core.
When it dries out, it will bind up inside the housing and eventually snap.
A "universal" cable core kit can be bought at autoparts stores. All that is required is to cut it to length, install in the housing.
From a gearing standpoint they should be the same because the registered speed was a function of the transmission rpm and that gear would remain the same with either speedometer. The actual works of the speedometer are only about 1"x2" inside the housing.
New 48-50 speedo face decals are available on e-bay all the time - might be as easy as gluing one of those on a 51/52 speedo.
I do know that teh 51/52 speedo had two brackets tacked onto th ebody of the speedo case to mount it directly to the dash. And the 48-50 was mounted to the instrument cluster which in turn mounted to the dash.
