52 F7 ford
Ok great, know anything about it??? Trying to find info on two speed rear end, how it works, I have noticed hydraulic units mentioned but none electronic like mine, also what model Holley carb is thatm are their rebuild kits avail, someone started to convert to 12 volt, alreay got rid of points with updated electronic ignition unit inserted into original dist, know anything about that??? I need an entire wiring harness as some jackass cut anything that confused them, are they the same as F1???? Should I stick with 6 volt, if so I need a Gen. any suggestions, someone put an alternator on it. The list keep going
