who sells ford 410 pistons affordable
Look around for a 390 "Truck" piston.
When Ford dropped compression ratios to get emissions down, they had a ready supply of 1.66" pin height "410" pistons just sitting around. Search for your oversize and pin height, you'll probably see what you need.
It sure would be a good time for dinosaurfan to drop in. He always has part numbers you can take to your local supply house.
you can go to www.rockauto.com, search under Mercury in 1966 and just look under a few vehicles for the 410fe, look under engine and than choose pistons and choose the .60 oversized ones you need
Go look in summit. I found some the other day!! KB makes a set of forged pistons for a 410 I believe you nee a compression height of 1.660"
Keith Black/KB Pistons 1139-060 - Keith Black Silv-O-Lite Cast Pistons
http://kb-silvolite.com/spistons.php...tails&S_id=157
on
chiefsfootball
10-27-2015 08:44 AM
Jontremblay
11-15-2010 10:58 AM
Andy MCcubbin
03-26-2009 12:31 PM
67 428 Fairlane Ranchero
01-30-2003 08:12 PM
sgreen
01-26-2001 09:58 AM
