89 f350 351 bogs under acceleration
I just got my 89 F350 going on the road, and Ive come across my first issue. Under hard acceleration, it feels like it only runs on some of the cylinders and it has very little power. If you rev it up in neutral, it doesnt seem to have this loss of power. Im going to pull codes, but what should I check for? Keep in mind that it had about a 1/4 tank of gas that was at least 5 years old in it and the truck wouldnt even idle until I ran some fresh gas and some fuel injector cleaner through it.
I just started to have this problem as well.
The changes that I made was a new Cap and rotor, cleaned the IAC and new filter. The miles on the plugs and wires was low so I did not replace them, but I did not have this problem before the new parts.
I also installed a new 190* heavy duty thermostat and the truck is running at 210* all the time now. Ran a bottle of sea foam in the front tank (it does not seem to matter if running on the front or rear tank).
Truck runs good and pulls nice if I am not wide open on it. When I am, it has a miss.
If I keep it on the floor, it will run good up to about 4K RPM and then start to miss and stumble, then when it grabs 2nd gear it runs ok again till about 4K again.
I am going to take a closer look at it this weekend and see if I can get a better idea of what is going on here. Since I have a crack in the Ex manifold, I am starting to think maybe my o2 sensor is ready to be replaced?
John
John
Okay, I did the wires, cap, and rotor and the truck runs much better. however, it still feels as though it loses all power at full throttle. It almost feels like the truck accelerates faster at 3/4 throttle ten at WOT. I also got a code 33 which seems to point towards my EGR. could this be associated ?
on
EGR problems will affect the way the engine runs under load, the computer commands it to open a certain amount proportional to load and rpm and if the valve isn't reacting properly the engine may run too lean and loose power. Both you guys need to check base timing and also that it advances correctly when the spout plug is reinstalled. Also check fuel pressure under these conditions, if that is dropping at higher rpm then it's possible the high pressure fuel pump is failing, the wiring is bad and it's not getting full voltage, or the fuel filter or selector valve is partially clogged.
I check fuel pressure its ok, the egr valve on the side of the throttle body is there supposed to be something coming out the bottom like a vacuum line i cant find a diagram also I have never checked the timing on a vehicle what kind of steps are involved I no you need a timing light but what are the next steps thanks so much for your help so far
on
Robert this is an ancient post you should have just started your own.
In any case the most common causes of this are plugged exhaust or low fuel pressure, an exhaust problem should be obvious but you need a gauge to test fuel pressure it's not good enough to just do a squirt test on the fuel rail, the system should make and hold 32-35psi when the engine is running and that should increase to 40-45psi under load, if you never get more than 30psi or it falls under load you have a weak pump and/or clogged filter.
captanron
06-17-2016 11:46 PM
Hunt89
17
06-25-2012 02:38 PM
boggerted
01-11-2011 04:37 AM
