Rear Axle Flange Gaskets
There is no gasket between the front brake backing plate and the spindle, it's just metal to metal. Now on the rear I don't know if there is a gasket or not because it should have a sealed bearing and a regular axle seal inside the axle housing itself. I assume you are using the original Dana 44 differential? Just FYI the 57 up Ford 9 inch differentials use the same rear brake backing plate and bearing size as the Dana 44s we have in our trucks, so you could just get rear axle flange gaskets for a 57 Ford 1/2 ton pickup that would work. I'm sure others will chime in soon and give you some more advice.
Some guys believe in liberally smearing silicone or RTV all over everything, everywhere, every time. I believe quite the opposite. If the mating surfaces are CLEAN and TRUE, I never use the stuff. The gasket is there to do the sealing and it doesn't need any help. If it leaks with a new gasket, then it wasn't clean, wasn't true, or it was over/undertorqued. RTV does come in handy if your mating surfaces are pitted (like an aluminum water outlet often is) or if no gasket is being used (like a differential cover). Your mileage may vary!
This one...
C5AZ1001A (replaced A8AZ1001B) .. Gasket / Obsolete
Fits: 1948/52 F1 / 1953/72 F100 / 1949/59 Ford Station Wagons & Sedan Delivery's (Couriers) / 1957/59 Ranchero's & Skyliner's (Flip-Top's).
Fits: 1955/60 Thunderbird / 1960/67 Galaxie/LTD / 1962 Fairlane/Meteor / 1962/63 Thunderbird and et cetera, et cetera, et cetera!
How many would y'all like?
C5AZ1001A =
GREEN SALES CO. in Cincinnati OH has 72 = 800-543-4959.
MILLER OBSOLETE PARTS in Binghamton NY has 32 = 800-546-7278.
VAN CLEVE FORD in Morton WA has 29 = 360-496-5999.
PARTS INTERNATIONAL in Farmers Branch TX has 20 = 888-727-0418.
FREESE MOTORS in Monticello IA has 18 = 319-465-3541.
KLIMESH MOTOR SALES in Calmar IA has 15 = 563-562-3241.
JST AUTOMOTIVE in Lebanon TN has 10 = 615-443-3086.
PIONEER FORD in Platteville WI has 10 = 608-348-3673.
Quantity between 1 & 9: There are 45 more at Ford Dealers, obsolete parts vendors.
A8AZ1001B =
FREESE MOTORS has 16.
C5AZ1001A =
A8AZ1001B =
artscott61
13
04-27-2021 01:10 AM
bhenders
05-17-2017 06:00 PM
4rdnut
07-15-2015 12:42 AM
queen of spades
08-28-2013 12:08 PM
Eddie
11-30-2001 08:06 PM
