75W140 Synthetic gear oil?
I have a 3:55 limited slip in my '94 Bronco. I have been using the 70-90 gear lube with no problems. Always add the additive however. Is there something I need to know about this weight lube and the limited slip diff?
Thanks
'94 EB,5.8,towing package, Rancho RSX7000 shocks,Westin nerf bar, Energy Suspension poly, keeping it basically stock
Thanks
Are you changing the fluid, or just topping off? Synthetic fluid should not need to be changed unless you got water into it. If you need a complete change, you may have to go to Ford for the fluid. If topping off, the 75W90 Mobil One will work fine. Unless you have a leak, you should not need any.
Ford started using this fluid on the Lightning in the mid '90's and now uses it in all rear-drive axles.
Jim
Jim
Im going by what the tag says; looking at my cover there is a tag on the upper left saying "75W140 SYNTHETIC OIL ONLY";the tag on the upper right of the cover gives my gear ratio 3:55....i was just going to change it for periodic maint.purposes.I dont know what came in it,and there is no water in it.
Gear Oil needs to be changed regardless of which type you run. I myself have read the factory service manual stating synthetic oil does not need to be changed, but it does. Synthetic oil does not prevent wear, the diff still wears and needs to be serviced, which means clean it out. People that tow heavy need to do this more often. And people who take their vehicles swimming need to do this right away. You can run synthetic oil if you want, but it is not needed if you service your diff every 25,000 or sooner depending on your driving situation.
