5.4L 3V Whistle
5.4L 3V Whistle
I remember a post a while back regarding this and was able to locate it in the search function. I thought i would throw it out there to see if there was any newer information regarding this.
My 06 5.4l tends to "whistle" during throttle up and seems to be most prevelant in the upper rpm as i go thru the gears (manual 6 spd). It sounds similar to a small turbo spooling up but not quite as loud. The original post comments on a possible air leak in the intake system and maybe the PCV system as well. I don't have an aftermarket CAI or throttle body spacer. The motor is currently stock except for a K&N filter element. This was not noticed after replacement of the filter and has seemed to get a little louder since i first noticed it. I have also not noticed any decrease in performance or mileage.
Have any of you had this issue and if so have you cured or found any problem?
Thanks
Dave
Thanks
Dave
There is a related TSB for the diesel engines.
https://www.ford-trucks.com/tsb/full...hp?tsb=05-21-9
I believe the CAI kits generaly make a note in their instructions that the "whistle" indicates normal function. I have no actual problem necessarily with the noise other than making the assumption (which i typically don't like to do) that it is something that may cause a future problem or failure of a specific item "or" the indication that something that may need to be serviced/cleaned etc..
I have not done anything as of yet other than a physical inspection. I plan on checking and or removing the AI system and inspecting and cleaning it if need be. I cleaned the K&N last week.
