Y Pipe HELP
Y Pipe HELP
Needing a Y pipe for a '93 F-350 460. Either a stock or an aftermarket bolt on. Can not seem to find any kind at all. Any help will be highly helpfull. Have developed a real bad exchaust leak.....they say it is common for the Y pipe flages to crack. No one knows how to fix, only replace, but can't find one.HELP THANKS
If so flow master makes a y connector 2.5" dual inlet and 3" outlet. FLO-Y250300 in the summit catalog.
No it isn't cracked, it is egg-shaped at the flange on the right side and the leak is getting worse. The Y pipe is or was a Ford only part, but now has been discontinued by Ford and there is none in the country anywhere in stock. However if I could get one from Ford the price was $1016.85, for a fringing Y pipe and I am not paying that kind of price. If I wanted to pay that price I would put on headers and rid the Y pipe, but would like to keep in stock for future restoration. I may have to go to a muffle place and see if they can make it round again. Ford had alot of trouble with those 460 FI Y pipes. The exhaust temps where so high they worped and that is what mine has done. I was looking for some suggestion to what other people have done in my case. I am now searching alot of junk yards, but have found they don't normally keep exhaust parts and there is a chance that it would be similar to mine. Thanks for the info and I am open to any and all suggestions or if anybody knows where a used one might be hiding. Thanks
The factory ford cat for the 460 has an ovaloid entry. The y or connector pipe is oval as well.
You are certainly correct in the high heat and warpage that occurs in the exhaust manifolds. The manifolds have more carbon in them and expand at a different rate than the heads do. This and the excessive heat is why they crack.
The high heat is primarily due to high exhaust back pressure. In addition the lack of power at part throttle requires WOT operation more often than is required in an upgraded combo.
The Y pipe is or was a Ford only part, but now has been discontinued by Ford BS!!
and there is none in the country anywhere in stock. Uh huh...yeah right!
What PINHEADED CLUCK gave you that crap info and ridiculous price?
F3TZ5246C has been replaced by F7TZ5246DA .. Y Pipe
STILL available from Ford!
MSRP: $578.68 // FTEpartsguy.com price: $493.03.
Fits: 1992/97 F250/350 460.
FTE sponsor = FTE Parts Guy: Ed Olson @ Parr Ford in Bremerton WA
FoMoCo parts depots have 69 available: 11 in Detroit, 11 in Memphis, 47 in Sacramento.
There's...at least...another 70 in dealers parts inventories. Closest dealer to you that has one is Larry Miller Ford in SLC UT.
But... you prolly won't get that FTE member discount price there.
According too two different dealers I have contacted said for a :
1993 F-350 4X4 Crew Cab with 460 FI, Automatic transmission, no resonator but with O2 sensor
Discontinued and none in the US of A
If I could get one the manufactors list price $1016.85 dollars
If you can re-verify that one of those part # will fit I would be glad to pay the shipping. However I have found out by checking with a few junk yards in the area that not all Y-pipes from the '92-'98 series are the same.
My left back pipe comes down and turns under/ between the oil pan and bell housing and Y's with the right bank pipe at the front of the transmission, where the O2 sensor is located then goes to the cat. It is a round clamp fitting at the cat not the square flange fitting as most I have seen. I have the short right bank pipe and the long one.
Please re-verify those part numbers as not having a square flange and havingthe short right pipe and I will really appreciate it.
Thanks
Thanks
Thanks
Thanks
93 F350 4X4 7.5L W/O RESONATOR WITH A E4OD TRANS WITH PRODUTION DATE FROM 2/93 with a single pipe to muffler
F7TZ5246DA still avail
if you have before 2/93 and two pipes to muffler then that shows to be obsolete.
Ed
Thanks
Thanks
btw: If you had put all those specs into your original post, I would not have had to spend 10 minutes comparing exhaust parts lists by staring at Ford microfiche slides using a Chrysler viewer & a magnifying glass!
The Chrysler viewers resolution is about 1/3 the size of the Ford viewer. I have a Ford viewer, but it needs some parts...which are obsolete.
PAL-EEZE when asking questions, list ALL the pertinent info.
FTEParts-Guy
Built 4/93 and yes it did have the two pipe to muffler, but that has long been gone. Sorry
OH! Sorry for the inconvience and the trouble I caused you Number Dummy to have to look though a microscope. Maybe being an X parts guy, you should have been the one verifing all the details before searching. Oh, I am just the dumb customer.
Sorry I took up your time.
I already knew it was discontinued, I was asking a simple question has to what my options are now.
FTEParts-Guy
after 2/93 should have been a single pipe to muffler but if that is long gone anyways who cares order the F7TZ5246DA AND BE DONE WITH IT.
I have sold hundreds of these in the past and I don't know how many cats for the 460. was kinda of a popular part for a while 15 plus years ago.
ed
You're not a dumb customer. What you are...is a thankless JERK with a **** poor additude.
Called Larry Miller Ford in SLC, UT. That number is for a 2-wheel drive F-350.
The number he said I need is a F7TZ5246BA (discontinued)
I am betting it is the long pipe, rather than the short, which is for the 4X4. Will it work on a 4X4???????????
Is anyone willing to bet the price of $500.00 that it will work on a 4X4 before I order it and then have to send it back if it doesn't?
Still asking for some options to fix my problem.
Thanks
Thanks
