Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 04-29-2009, 09:45 PM
Rushmore X's Avatar
Rushmore X Rushmore X is online now
2003 Ford Excursion
Rushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to behold
thoughts on pre-treatment?
Just wondering what you guys thinks of this. Our oil titrates rather high (7-8 grams per liter or more) so we have been adding glycerol from the previous batch to new oil in the reactor in order to reduce the acidity. This reduces the amount of KOH needed by almost half, therefore reducing cost. I'm wondering if the same thing can be done adding glycerine to the oil in the settling tank before it goes into the processor (so less possibilty of some being left in the reactor). As you can see from the picture, the outlet into the processor is about 15 gallons up from the bottom of the tank. My thought is that the glycerine would settle at the bottom of the tank and be drained out after neutralizing some of the acid in the oil. Would use second round glycerine for this. What do you think?
__________________
Trent - 2003 Excursion (Eddie Bauer) 4X4, 7.3, Hellvig antisway bar, 6637 intake mod, 4" MBRP w/ 5" tip, DP tuner, IH up-pipes, redhead steering box, 6.0 trans cooler, ISSPRO & Aeroforce gauges in A-pillar, Wicked Wheel, "Bullet Proof" Transmission rebuilt by Rapid Diesel, extra leaf spring added all around, more to follow! Gone BIO!!!
2002 TDI New Beetle - also likes Bio.
  #2 (permalink)
Old 04-30-2009, 10:12 AM
fabmandelux's Avatar
fabmandelux fabmandelux is offline
1935 Ford pickup
fabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputation
It' worth a try Trent. My WVO titrates about 3-4, so I've never had that problem.
__________________
Oregon Chapter Leader My friends call me Don.
"I always keep a supply of stimulants handy in case I see a snake, which I also keep handy" WC Fields
  #3 (permalink)
Old 05-13-2009, 08:06 PM
bradyracing bradyracing is offline
Garage is empty, add now
bradyracing is starting off with a positive reputation.
I believe in it 100% for a bunch of reasons. You don't ever have enough to do all incoming oil so we just pre-treat oil that is over a titration of 5 or suspected of being a little too wet. Oil that is under five just gets processed as normal. We even built a special "reactor" outside (a 1000 gallon vertical tank on legs) to do nothing but pre-treatment. We put in about 350 gallons of fresh glycerine at room temperature and about 600 gallons of oil that has been heated to 175 degrees. The hotter than normal oil heats the glycerin so we don't have to. We mix for two hours with a 2 inch pump, shut the pump off, and let stand overnight.
__________________
2004.25 F250 CC Powerstroke on B100, 220K miles
1992 F350 CC SRW 4x4 Cummins powered, on B100
Biodiesel maker
http://community.webshots.com/user/b...host=community
  #4 (permalink)
Old 05-17-2009, 12:53 PM
Rushmore X's Avatar
2003 Ford Excursion
Quote:
worked real well with the last batch, cut the titration almost in half to 4.8 g per liter. (I'm envious of those who start with oil better than that...)
__________________
  #5 (permalink)
Old 05-17-2009, 10:39 PM
Did you gain any oil?
We bought 900 gallons of oil from a renderer onetime that smelled like ammonia and titrated at 18 NaOH. Ran it through the glycerin stripper three times and lowered titration to four and gained 200 gallons of oil total. The oil is pulling trapped bio and MeOH from the glyc. That is why all of our glyc will be used onetime to treat oil to pull all of the good stuff out that normaly is burned or thrown away besides the fact that it reduces titration by roughly half.
__________________
Biodiesel maker
  #6 (permalink)
Old 05-18-2009, 10:02 AM
Rushmore X's Avatar
2003 Ford Excursion
Think you're right, didn't measure but seem to gain a couple gallons on a 35 gallon batch. 2nd round Glycerol is sure thicker and darker than 1st run. need to figure a way to recover methanol off of it, we are afaid that it we put it in the processor, it will plug up as methanol is driven off... Might have to make a seperate processor for that.
__________________
  #7 (permalink)
Old 05-24-2009, 10:31 PM
Knotwild Knotwild is offline
Knotwild is starting off with a positive reputation.
I don't believe you actually gain oil, but do believe (as brady racing mentioned) that the gain is related to biodiesel and methanol contained in the glycerin. My oil starts out titrating 4-6 and I am getting titrations of 0.5-0.75 consistently. I round it up to 1.0 and use 18% methanol for the reaction. Always passess the 27/3 test.
Interesting side note. I have been using KOH and a few months ago I started having batches that did not pass the 27/3 test. I had to up the KOH base from 7.0 to 9.0 g/L to end the problem.
__________________
97, Regular cab 4x4, 5sp, 3" downpipe, 4" MBRP exhaust, 6637 intake mod, Dieselsite 203 thermostat, Airdog II electric fuel system with fuel bowl delete.
  #8 (permalink)
Old 05-31-2009, 05:11 AM
jdieselih jdieselih is offline
jdieselih is starting off with a positive reputation.
Really? Could this be a case of the KOH being somewhat less than 90% pure? I've never really had much success with a glycerol caustic strip. I have such a crapload of glcyerin though I may as well give it another shot. How are you guys adding it to the processor? My "good oil" could defintely benefit and my "bad oil" might even be made good enough that I can avoid the acid base method or 2 stage base with it. What say you?
  #9 (permalink)
Old 05-31-2009, 11:53 AM
Rushmore X's Avatar
2003 Ford Excursion
Quote:
We add the Glycerol from the prior batch + the new oil, heat to 50c while circulating for 2 hrs, then let sit overnight and drain off the 2nd rd Glycerol. Process as usual after that with 5 gals methoxide (17%) instead of the usual 7+ gals. 2nd rd Glycerol is much darker than 1st rd. Adds a day, but reduces the titration by 40-50%.
__________________
  #10 (permalink)
Old 05-31-2009, 04:33 PM
I'll try that next time and see what it does. I had not done it that way before I had sort of used it like I would a caustic strip in the holding container. I've heard other good things about this and its certainly worthwhile looking into it.
Tags
glycerine, pretreatment
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
