7.3 liter diesel MPG's
Old 09-10-2014, 07:54 PM
jgavac's Avatar
jgavac
jgavac is offline
I bet that something is wrong internally. When was the last time it had a tune up?
-Jameson
  #77
Old 09-14-2014, 05:39 AM
99xjon's Avatar
99xjon
99xjon is offline
Originally Posted by John Such
ALL diesels are direct injected!!!!!!!!!!
lol, this should be good
  #78
Old 09-14-2014, 10:02 AM
F350 1990's Avatar
F350 1990
F350 1990 is offline
Originally Posted by gthbryce
What sort of MPG's does the 7.3l engine trucks get. My efi 460 gets about 10..
My 02 7.3 gets 19-23, but it's been pampered. 460's are hard on fuel (8-12mpg), but can be set up to achieve in excess of 15.
  #79
Old 09-14-2014, 10:14 AM
FORDF250HDXLT's Avatar
FORDF250HDXLT
FORDF250HDXLT is offline
Originally Posted by F350 1990
460's can be set up to achieve in excess of 15.
oh come on now.
  #80
Old 09-14-2014, 10:29 AM
F350 1990's Avatar
F350 1990
Originally Posted by FORDF250HDXLT
oh come on now.
All within the art of the possible.............I personally see no reason why one can't mod a 460 engine, re-gear it, put it on a diet and get in excess of 15. Others have (and that was a Big Centurion to begin with):
http://performanceunlimited.com/proj...ine_series.pdf
  #81
Old 09-14-2014, 10:49 AM
FORDF250HDXLT
oh you want to play with the impractical lol ok.well here ya go;
Vehicle efficiency upgrades: 30+ MPG in 2.5ton commercial truck
  #82
Old 10-04-2014, 12:18 PM
Double O's Avatar
Double O
Double O is offline
Hey guys new here, thought i would chime in. 2000 f-250 7.3 auto, empty scaled 7500 lbs, loaded 3 job site boxs filled with tools, scaled 10,500. 30 gals = 756 miles = 25.2 mpg. loaded is daily driver. when empty maybe i gain 1.5 but for conversations sake it stays about the same. Tip- I dont blow coal every light nor do I drive it like a race car. standard mods., cold air, 4" pipe and php hydra chip, ww2. Now with that said developed oil in fuel bowl, and a fuel restriction problem and mileage dropped to 14 mpg. hope it helps
  #83
Old 12-06-2017, 04:31 PM
Joshua Hahn's Avatar
Joshua Hahn
Joshua Hahn is offline
Indirect sequential fuel injection
IDI'S have indirect SEQUENTIAL fuel injection same as regular fuel injection EXCEPT THEY HAVE AS MANY INJECTORS AS CYLINDERS although it is still indirect, because it doesn't go from fuel tank to combustion chamber, it goes into the fuel system first.
  #84
Old 12-06-2017, 08:32 PM
Salts's Avatar
Salts
Salts is offline
ummm... I think it's indirect because it doesn't get shot straight into the cylinder it's into the prechamber ...7.3 direct injectors inject directly into the cylinder it all goes from tank to a "fuel system" lift pump, injection pump, or unit injectors, then to the combustion chamber or prechamber in the case of idi ...this nonsense about idi being direct injected cause its not forward of the valve hahahaha what has been going on, on this site? it can't be forward of the valve that's not how stratified injection works ...some yall confused this with homogenous spark ignited combustion works aka gasoline ...the point of...you know what never mind late to the party anyway...97 7.3 575k factory injectors..15mpg hell or high water
  #85
Old 12-07-2017, 12:17 AM
imoneyco's Avatar
imoneyco
imoneyco is offline
Keep it stock with tunes and youll get descent mpg
  #86
Old 12-07-2017, 08:44 AM
540milotalon's Avatar
540milotalon
540milotalon is offline
Ditto on the IDI pre injecting into the pre chamber. I seriously believe the only way a 460 gas will get 15+ mpg is going straight down a pine tree with the switch off.
queen of spades
1983 - 2012 Ranger & B-Series
02-16-2018 06:13 PM
thelonius
2017+ Super Duty
18
08-13-2017 11:08 AM
SNIPER168308
06-12-2017 04:13 PM
Hammer40330
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
26
06-29-2016 08:02 PM
NM_91IDI
06-10-2016 07:38 AM
Quick Reply: 7.3 liter diesel MPG's
