need suggestions
need suggestions
I have an F 150 1997 4.6 I have replaced the DPEF put about 200 miles on it and the check engine light came on again. Replaced EGR and drove it another 200 miles and the check engine light came back on. I took the throttle body off and cleaned the carbon. It was completely clogged. The codes is P0401 insufficent flow EGR. Does anyone have any other ideas. I checked the hoses however the upper hose on the throttle body leaves an awful lot of black residue on your hand when you touch it.
need suggestions
****** http-equiv="Content-Type" content="text/html; charset=utf-8">****** name="ProgId" content="Word.Document">****** name="Generator" content="Microsoft Word 10">****** name="Originator" content="Microsoft Word 10"><link rel="File-List" href="file:///C:%5CDOCUME%7E1%5CFRANKH%7E1%5CLOCALS%7E1%5CTemp%5 Cmsohtml1%5C01%5Cclip_filelist.xml"><!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><style> <!-- /* Font Definitions */ @font-face {font-family:"Palatino Linotype"; panose-1:2 4 5 2 5 5 5 3 3 4; mso-font-charset:0; mso-generic-font-family:roman; mso-font-pitch:variable; mso-font-signature:-536870009 1073741843 0 0 415 0;} /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-parent:""; margin:0in; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:14.0pt; font-family:"Palatino Linotype"; mso-fareast-font-family:"Times New Roman"; mso-bidi-font-family:"Times New Roman"; color:#231F1F;} @page Section1 {size:8.5in 11.0in; margin:1.0in 1.25in 1.0in 1.25in; mso-header-margin:.5in; mso-footer-margin:.5in; mso-paper-source:0;} div.Section1 {page:Section1;} --> </style><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} </style> <![endif]--> I have run a wire through every pipe and hose coming off the throttle body. I did not fin a plugged line or hose. Would a bad gas cap give me a PO401 code? Thanks for any suggestions.
StaticChrome
Modular V8 (4.6L, 5.4L)
04-19-2012 04:16 PM
