Can this be fixed?
Can this be fixed?
My partner was experimenting with water washing, and formed an emulsion. (I'm dry washing mine!) Anyway, we pumped out the reactor into a few smaller drums and let it settle out. Ended up recovering about 25 gallons of bio out of about 35. The recomended proceedure for dealing with this bio was to put it back in the reactor, heat it up, and let the water settle out. the water didn't seperate as was claimed it would do, was rather creamy. So the next recommendation was to break the emusion and get the water out by reintroducing glycerine from previous batches, heating it up, and draining the glycerine off.
As the reactor ran, and the temp went up, the mixture got thicker, to the point wher the venturi wouldn't work and I believe the pump is no longer drawing fluid. I shut the whole thing down down and am hoping that the heavier stuff will again seperate out and the pump will again work. Since our processor will run about 40 gallon batches, would it be advisable to try and add 5 more gallons of bio to the mixture in order to thin it? How about methanol?
Rushmore X
Bio-diesel, Propane & Alternative Diesel Engine Fuels
08-06-2017 10:40 AM
Rushmore X
05-14-2010 11:50 AM
Rushmore X
04-02-2009 07:05 PM
TXHillCountry
13
09-25-2008 07:46 PM
