289?
289?
Bought a shell truck no engine or tranny for 200 its 1960 f100. Of course stock they came with 223 272 and 292. But around here where I live in Montana I can't find one for s###. However there is a running 289 from a Mustang for cheap closer than I could find the straight or the y blocks? Would a 289 be a very bad choice for a 1960 f100 2wd? Would it be sufficient or doable? would rather find one close than travel 5 6 700 miles but I will if I have to. Just trying to fix it up a little not looking to make it a show piece. If it would work I think it has the 5 bolt pattern what would give me more choice in transmissions the 289 or y blocks?
Was also thinking about a 390? they are alot available, would a 390 be a good choice?
Thanks,
Jason Henry
Thanks,
Jason Henry
Sorry, long day today so short answer. Check out Julie’s (Julies Cool F1) gallery. In my sometimes not so humble opinion, the 289 would be just fine, much lighter and with all due respect to Julie, maybe a little bit newer design. More and cheaper performance parts are available for the 289.
Received 1,353 Likes
on
In my 51 I have a 390 and it's a little harder to get parts for - stupid things like heater hose nipples, etc. It's quite something - wanna check out conditions in the bed, just floor it, and you'll be there.
The 390 presented a few more space and clearance challenges, but has quite a bit of get-up-and-go!
390 with a C6 or a 289 with a C4 - like Morris said, you can't go wrong either way. Have you considered a 351W with a C6? Might be the best of both worlds!
Before you buy that 289 check whether it is an early one or a late one. The late ones take the same bell housing bolt pattern as the 302. The early ones have are different. I am getting ready to drop a 289 or 302 with AOD in my son's 60 F100. I have decided to go with a 3.25 9 inch from a 69 F100.
If the 289 is a 5 bolt pattern you will be severely limited to what you can use for a trans.
Other than that the 289 is a sweet engine unless you are wanting a torque monster.
A 390 is always a good option.
The 390 is a bit of a beast. If you're using a bellhousing with 'ears' like a stock 352 would use, I think you might be limited to transmissions like the T18 four speed with granny low, the top-loader HD 3 speed, the Clark 5 speed and similar.
What kind of use are you going to give this truck?
The 5 bolt pattern 289 was only used thru 8/22/64 with the 3 speed manual, Borg Warner T-10 4 speed and the C4.
The waterpump used with this block is aluminum, as is the timing cover.
These parts are not the same as the 6 bolt block.
btw: Is IT a 289?
Since it's from a 1965 Mustang assembled before 8/23/1964, it could be a 260 as this engine was also available in these early Mustangs.
Only the bore is different, the stroke is the same (2.87").
1965 Mustang's were introduced 4/23/64 and thru 8/22/1964 came with: 170 & 200 I-6's, 260 2V's, 289 2 & 4V's and the Hipo 289.
After 8/22/1964, the 170 and the 260 engines were dropped, as was the 5 bolt engine.
This reminds me...that on sale day...352's and 360's magically become 390's.
221/260's on sale day, magically become 289's...or 302's!
btw: Is it a 390? The stroke is 3.78" if it is.
If the stroke is 3.50"...it's a 352 or 360.
