Let me know for oasis report
Hi, Im new here and work for a ford dealer and can run oasis reports if needed. I am also buying a 2005 Excursion Limited and need a carfax if anyone can help on that. the vin# is 1FMNU43S25ED47687 Thanks again and hope I can help!
Hmm if you don't mind. Id like to see an oasis report for 1FMSU45P44EA00159
Bought it already never thought to look this up.
Thanks
Thanks
on
here ya go danimallv
OASIS RESULT:
1FMSU45P44EA00159
USA
EN
04/22/2009
09:55:34
FCXWS446
© Copyright 2002-2008 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2004 EXCURSION BODY STYLE
4 DR EDDIE BAUER 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
C1 ENGINE CALIBRATION
3L11ON0A
WARNING MESSAGES
VERIFY STATE REGISTRATION, VIN MAY BE ELIGIBLE FOR CALIFORNIA EMISSIONS WTY
ARN MESSAGES
ATTENTION TECHNICIANS AND SERVICE MANAGERS:
BEFORE REPLACING FUEL INJECTORS FOR COLD ENGINE OPERATION SEE TSB 08-26-03
BEFORE REPLACING 6.0L CYLINDER HEAD GASKETS REFER TO 09-08-03
BEFORE REPLACING 6.0L TURBOCHARGER OR VGT SOLENOID REFER TO 08-16-13
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
01/25/2004 BUILD DATE
07/21/2003 SALE MILEAGE
00040
OUTSTANDING FIELD SERVICE ACTIONS
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
09/22/2008
DEALER: Ed Wittmeier Ford Lincoln-Merc
WARRANTY CLAIM NUMBER: 603908 ODOMETER: 098863M
PART NUMBER PART DESCRIPTION QUANTITY
LABOR OP
CONDITION CODE
CONDITION DESC
4C4Z 8592AA CONNECTION-CYL HD WA 001 8005D D1 POROSITY
3C3Z 9P458AA KIT - VLV EGR 001 8575B
VC 7B 004 8592A
6C3Z 8A080B COOLANT O/FLO BOTTLE 001 8080A
CHECKED FOR CONCERN FOUND LEAK AT EGR CONNECTOR HOSE REPLACED RECHEK CED FOUND DE GAS BOTTLE CRACKED REPLACED RECHECKED OK
Click Here for Full Warranty History
| On-line 1878
END OF OASIS REPORT FOR 1FMSU45P44EA00159
OASIS RESULT:
1FMSU45P44EA00159
USA
EN
04/22/2009
09:55:34
FCXWS446
VEHICLE INFORMATION
VEHICLE DESCRIPTION
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
3L11ON0A
WARNING MESSAGES
ARN MESSAGES
WARRANTY START DATE
00040
EXTENDED COVERAGES
09/22/2008
LABOR OP
CONDITION CODE
CONDITION DESC
VC 7B 004 8592A
| On-line 1878
Standard Claims List For Model Year 2004
Detailed Vehicle Specification
VIN VEH LINE MKT DERIV BODY CAB VER SERIES DRIVE TYPE PLT CD TRS CD ENG CD PROD DATE WARR DATE SELLING DEALER SELL CNT TIS WCC CPSC_6 PREF BASE SUFF CCC CD DIST(Miles)
1FMSU45P44EA00159 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 21-JUL-2003 25-JAN-2004 172420 USA 0 6Y05 000001 * TDRIVE * A96 82 9
AWS Claim Key: 43738 Trx Code: R7U Labor Hrs: 0.4
Dlr Cd-Sub Cd: 07750 - * Name: ED WITTMEIER FORD LINCOLN-MERCURY Ph: 530-8958181 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:17-SEP-2003 Doc #:88413201
Cust Comments: PERFORM 6.0L DIESEL ROADTEST WORKSHEET; CERTIFIED DIESEL TECHNICIAN...
Tech Comments: CUSTOMER ROAD TESTED WITH TECHNICIAN
1FMSU45P44EA00159 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 21-JUL-2003 25-JAN-2004 172420 USA 0 2G05 031405 * RECAL * D50 79 10
AWS Claim Key: 62656 Trx Code: 1 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 07750 - * Name: ED WITTMEIER FORD LINCOLN-MERCURY Ph: 530-8958181 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:08-OCT-2003 Doc #:88600001
Cust Comments: PERFORM CAMPAIGN #03T02; CALIBRATION UPDATE..
Tech Comments: PERFORMED RECALL AS REQUESTED
1FMSU45P44EA00159 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 21-JUL-2003 25-JAN-2004 172420 USA 7 5Q02 110203 F81Z 3N999 BA N17 D1 11057
AWS Claim Key: 1444713 Trx Code: 1 Labor Hrs: 2.3
Dlr Cd-Sub Cd: 07750 - * Name: ED WITTMEIER FORD LINCOLN-MERCURY Ph: 530-8958181 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:26-JUL-2004 Doc #0975401
Cust Comments: CUSTOMER STATES THAT WHEN BRAKING & TURNING AT THE SAME TIME SHE GETS A GRINDING SOUND CHECK & ADVISE
Tech Comments: ROADTESTED VERIFIED NOISE FOUND SEEPING HOSE AT POWER BRAKE BOOSTER. VEHICLE WAS LOW ON P S FLUID. REMOVED POWER ASSIST
1FMSU45P44EA00159 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 21-JUL-2003 25-JAN-2004 172420 USA 8 6D01 011001 * 7862900 * S50 33 13207
AWS Claim Key: 1817301 Trx Code: E84 Labor Hrs: 0
Dlr Cd-Sub Cd: 07750 - * Name: ED WITTMEIER FORD LINCOLN-MERCURY Ph: 530-8958181 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:31-AUG-2004 Doc #1293503
Cust Comments: CUSTOMER STATES THAT THE BACK OF THE MIDDLE SEATS THE COVER THAT GOES DOWN WHEN THE SEATS ARE FLAT WONT STAY UP
Tech Comments: RAN OASIS NO TSB S OR SSM S FOUND RECOMEND SUBLET FOR REPAIRS.
1FMSU45P44EA00159 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 21-JUL-2003 25-JAN-2004 172420 USA 8 2G04 000615 * DIAG * E29 42 13207
AWS Claim Key: 1817302 Trx Code: S07 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 07750 - * Name: ED WITTMEIER FORD LINCOLN-MERCURY Ph: 530-8958181 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:31-AUG-2004 Doc #1293501
Cust Comments: CUSTOMER STATES THE CHECK ENGINE LIGHT IS ON CHECK & ADVISE
Tech Comments: INSPECTED FOR CONCERN CHECK ENGINE LIGHT IS NOT ON AT THIS TIME.SELF TEST AND CODE P2263 MEMORY PASS KOEO KOER PERFORM
1FMSU45P44EA00159 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 21-JUL-2003 25-JAN-2004 172420 USA 17 1H03 030008 4C3Z 9F452 A E29 42 31065
AWS Claim Key: 6637987 Trx Code: S07 Labor Hrs: 4.7
Dlr Cd-Sub Cd: 07750 - * Name: ED WITTMEIER FORD LINCOLN-MERCURY Ph: 530-8958181 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:01-JUN-2005 Doc #3446301
Cust Comments: CUSTOMER STATES THE CHECK ENGINE LIGHT WAS ON YESTERDAY AND TRUCK WAS RUNNING ROUGH. LIGHT IS NOT ON TODAY. CHECK & ADVISE.
Tech Comments: INSPECTED FOR CHECK ENGINE LIGHT ON SELF TEST AND CODE P2263 MEMORY PASS KOEO KOER BUZZ TEST FUEL PRESSURE OK. MONITOR EGR VP PID AND ACTIVATE EGR VALVE FOUND EGR VALVE STICKS OPEN PINPOINT TEST AND FOUND BAD EGR VALVE REPLACED VALVE REFLASHED PCM TO LATEST LEVEL RECHECKED OK GENO
1FMSU45P44EA00159 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 21-JUL-2003 25-JAN-2004 172420 USA 25 2H01 030008 3C3Z 6K854 DA E42 01 45290
AWS Claim Key: 8504679 Trx Code: E72 Labor Hrs: 6.4
Dlr Cd-Sub Cd: 07750 - * Name: ED WITTMEIER FORD LINCOLN-MERCURY Ph: 530-8958181 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:30-JAN-2006 Doc #5362201
Cust Comments: C S THAT THERE IS EXHAUST LEAK THAT YOU CAN HEAR IT ALL THE TIME MUST REALLY LISTEN SHE STATES THAT TRUCK SOUNDS DIFFERENT THAN BEFORE.
Tech Comments: INSPECTED FOR THE CONCERN CHECKED FOR LEAK WITH SMOKE MACHINE REMOVED EP SENSOR AND FILLED SYSTEM WITH SMOKE RECOMMEND Y PIPE, GASKETS AND CLAMPS REMOVED TRANS AND REPLACED Y PIPE RETESTED OKAY KAT
1FMSU45P44EA00159 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 21-JUL-2003 25-JAN-2004 172420 USA 36 * * * * * * * 64650
AWS Claim Key: 11000910 Trx Code: 06E17 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 07750 - * Name: ED WITTMEIER FORD LINCOLN-MERCURY Ph: 530-8958181 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:03-JAN-2007 Doc #7793703
AWS Claim Key: 11000909 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 07750 - * Name: ED WITTMEIER FORD LINCOLN-MERCURY Ph: 530-8958181 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:03-JAN-2007 Doc #7793704
1FMSU45P44EA00159 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 21-JUL-2003 25-JAN-2004 172420 USA 37 2E06 030008 3C3Z 9F838 EA E29 42 67868
AWS Claim Key: 11124270 Trx Code: E72 Labor Hrs: 3.5
Dlr Cd-Sub Cd: 07750 - * Name: ED WITTMEIER FORD LINCOLN-MERCURY Ph: 530-8958181 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:01-FEB-2007 Doc #8004001
Cust Comments: CUSTOMER STATES THAT THE CK ENGINE LIGHT IS ON.AT TIMES ENGINE WILL IDLE UP AND DOWN AND AT TIMES ACTS LIKE WANTS TO DIE AT A STOP. CK AND ADVISE
Tech Comments: 2 INSPECTED FOR CONCERN PERFORMED EEC 5 TEST NO COMMUNICATION REPLACE BLOWN FUSE. RETEST P2285 ICP LOW. PERFORMED PIN POINT TEST AND MONITOR PID DATA. REMOVED AND REPLACED ICP SENSOR AND HARNESS, OIL SOAKED. CLEARED CODE AND RETEST PASS MS
1FMSU45P44EA00159 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 21-JUL-2003 25-JAN-2004 172420 USA 40 1H03 030008 * 9F452 * E29 55 70534
AWS Claim Key: 11650022 Trx Code: E72 Labor Hrs: 2
Dlr Cd-Sub Cd: 07750 - * Name: ED WITTMEIER FORD LINCOLN-MERCURY Ph: 530-8958181 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:30-APR-2007 Doc #8552604
Cust Comments: CUSTOMER STATES THAT THE CK ENGINE LITE IS ON
Tech Comments: 2 INSPECTED FOR CONCERN VERIFIED CONCERN. PERFORMED EEC TEST P 0401 RAN OASIS. FOUND TSB 06 19 6. PERFORMED TSB EGR FUNCTIONAL TEST FAILED. REMOVED AND CLEAN EGR REINSTALL FUNCTIONAL TEST PASSED. ROAD TEST LIGHT CAME ON P0401. FOUND OIL ON IAT2 CONNECTOR ALSO OIL IN EBP. REMOVED NAD REPLACED MAIN ENGINE HARNESS. NOTE WHEN DISCONNECTING CRANK SENSOR
1FMSU45P44EA00159 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 21-JUL-2003 25-JAN-2004 172420 USA 40 2B01 030706 3C3Z 6C315 AA L65 D1 70534
AWS Claim Key: 11650021 Trx Code: E72 Labor Hrs: 7.1
Dlr Cd-Sub Cd: 07750 - * Name: ED WITTMEIER FORD LINCOLN-MERCURY Ph: 530-8958181 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:30-APR-2007 Doc #8552606
Cust Comments: INSPECT FOR OIL LEAK AT ENGINE AREA
Tech Comments: CHEKED FOR OIL LEAK FOUND LEAK AT CRANK SENSOR ALSO FOUND MAIN ENGINE HARNESS 12B637 OIL SOAKED NEEDS TO BE REPLACED REPLACED CRANK SENSOR AND HARNESS RECHECKED NO LEAKS
1FMSU45P44EA00159 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 21-JUL-2003 25-JAN-2004 172420 USA 57 1G01 03XXXX 4C4Z 8592 AA L87 D1 98863
AWS Claim Key: 12898148 Trx Code: E72 Labor Hrs: 3
Dlr Cd-Sub Cd: 07750 - * Name: ED WITTMEIER FORD LINCOLN-MERCURY Ph: 530-8958181 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:22-SEP-2008 Doc #:60390801
Cust Comments: CHECK FOR COOLANT LEAKING FROM ENGINE AREA
Tech Comments: CHECKED FOR CONCERN FOUND LEAK AT EGR CONNECTOR HOSE REPLACED RECHEKCED FOUND DE GAS BOTTLE CRACKED REPLACED RECHECKED OK
Can you do this one as well? 1FMSU43P25EB53000
You can e-mail it to me if you'd rather - tx_silver AT tx DOT rr DOT com
Thanks.
My carfax expired seven days ago, or I'd run it. Sorry.
TX
Thanks.
TX
