Massive request for 1st appearance
Hey everybody. I am doing a restomod on a 1966 F100 custom cab. My desire is to build a SC 5.4. As I have not purchased anything for the powertrain yet, what is the best option? I want this truck to be scary fast! This will be a scratch build, so I have no problem looking at all options. SOHC vs DOHC? heads...cams...superchargers...compression ratio. I want unadulterted opinions on all of this stuff. My goal is 700+ hp. I am a pretty good scrounger and there is a great salvage yard with a locator service near me. For the powertrain, we'll say that money is not really a tremendous concern and time is plentiful.
How in-depth of an engine build are you looking to perform?
I know alot of guys with the 2004+ 5.4 3v with stock internals running 500+ wheel HP (roughly 600 crank HP) using 10-12 psi of boost and simple bolt-ons. nothing internal changed from OEM parts.
with a built motor, and boost at 12+ psi...I can easily see 700 crank HP
if money isn't an issue, for $15,000 you can get a brand new running 5.4 4v (GT 500 motor) from Ford Racing...they dyno out at about 440-450 RWHP. add some extra boost and tuning and you can easily see 500+ RWHP without much effort
Thanks Tylus.
I don't want to go the crate engine route. I want to build this thing myself. I can get a lot more for my money that way. Before I came to my senses, years ago, I was doing TPI swaps into Chevy trucks. I mean like in the early 90's. I've also built a few 429 Thunderjet/ Cobra Jet platforms over the years. There is a certain satisfaction in getting greasy.
A guy that lives near me had a twin screw Kenne Bell, stage three heads and cams, some sort of piston change, and I think a bolt on air intake modification. What performance could be realistically expected from this type of arrangment...with a proper tune?
I also need to now what to look for in terms of engine/transmission cores. I don't want to go the lightning engine route because I'm doing a total rebuild and changing the supercharger anyway.
Solid 5.4 cores are readily available at a decent price. Mention lightning at the salvage yard and the price jumps by the thousands. It's only a matter of knowing what years and casting numbers to look for and stay away from.
All info and opinions are welcome.
I personally wouldn't go the Lightning route. the 2v is a good engine, but the 3v will offer more HP options down the line. I'm only running 6 psi and have roughly 412 crank right now...non-intercooled. That same 6 psi intercooled is good for 445 crank.
vs. the Lightning which is 380. so roughly a 65 HP gain when switching from 2v's to a 3v setup
the 5.4 blocks are essentially the same on the bottom end, and the new 5.4 uses the same parts...it's just a difference between Forged and Cast.
as I mentioned earlier, you can take a 100% stock 5.4 3v, and run 10-12 PSI + tuning...you are easily looking at the 500 HP mark.
in terms of motors you want...I personally would get a 2008 5.4 3v block and heads. That will have the newest spark plug design (the one that doesn't stick). Then build it internally like a L block is built
then, add about 15 psi of boost + tuning and you'll have a real monster
granted, the L block is forged and re-inforced a bit...but after you do the same to the 3v motor...it has alot more HP options IMO
and that would be using OEM parts...basically a motor straight off the assembly line with a Supercharger installed, and nothing else but the bigger pulley
after the 500 HP mark, the 3v needs a better MAF, full exhaust, port/polishing, high flow fuel pumps...basically the usual bolt-ons
haven't heard of anybody doing a head/cam swapout though...but most people are satisfied with 500-550 RWHP. That is my eventual goal
oh yeah, forgot about those bad puppies
have you considered running a 4v 4.6 motor?
You can get a 2000+ Cobra motor for a pretty good price...and the Mach 1 has a slightly detuned version that is still 4v....and then of course there is the 2003-2004 Terminator 4.6 4v. With nothing but a tune and bigger pulley it will put down about 450 HP no problem
Read this article. It should give you some more ideas.
http://www.teamjdm.com/articles/JDM_Motor.pdf
I run a little 2.3 KB (the newer ones are 2.6 & 2.8) on a 5.4, stage 3 heads stage 2 cams. My motor has forged pistons,rods and crank. I put a Lightning intake on it and sold the M112 and replaced it with the 2.3 KB. Naturally you need upgraded fuel system and bigger MAF. 60# injectors with 2 Walbro 255lph in-tank fuel pumps.
I'm making 594 RWHP on a tune with low timing,nothing crazy. So crank HP is about 750.
